June 2, 2020, 06:01 |
volScalarField definition and IOobject
Rep Power: 5 |
Dear Openfoam exporters,
I am confused about the Openfoam field creation. Just as the following script, when the volscalarfield is defined. Its name is declared as A. While in the IOobject, the file name is "B". So in the case files, the "B" file is read into as the volscalarfield A? And in all the settings of fvscheme and fvsolution files, the variable is needed to set for A instead of B. Is it correct? volScalarField A ( IOobject ( "B", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh ); |
June 2, 2020, 07:42 |
A little explanation of registers
#2 | |
Carlos Rubio Abujas
Rep Power: 9 |
Hi Yongqiang66, There is a concept inside OpenFoam called register A register will store the reference of different objects, such a de volScalarField, with whatever name you assigned to it. In your particular example the name inside the register is B. In this case, the mesh is acting as a register. The important thing to have in mind is that your volScalarField, the real data, is living in a particular memory address. The register knows how to link a particular label (B) to this memory space, so you can recall it whenever you like. To avoid being calling the register multiple times you can store these address in a "variable". In your example "A". "A" knows where the data is (memory space) and how to deal with it (class type), so it has no need to call the register any further to manipulate this data. The fact is that the name of the variable is only important in your specific code, the name is not linked with the register label. It is just a convenient name for you to manipulate along the coding procedure. Once you finished, on the compiling process, this variable name will be vanished and substituted by the memory address. Inside OpenFoam, other manipulation has to be done with their fields: accesing the data, reading, writing... and for that purpose it uses the register. So when you want to access that information from other program, what prevalence is the label assigned to the register, not the variable name. Inside your boundaryCondition, fvScheme of fvSolution you shall be using the register label (B) and never the variable name (A). I hope that help you understanding what is going on. Good luck! |
June 2, 2020, 08:46 |
#3 | |
Rep Power: 5 |
Hi Crubio, Thank you very much. It is really helpful. So during the programming of the solver, the variable name can be called. Here it is "A". "A" can be called in the equations. While running the case, the register should be used. That refers to "B". The name of "B" needs to appear in fvscheme and fvsolution. Is it correct? I am not very confident about my understanding. Best Regards, Yongqiang |
June 2, 2020, 10:46 |
A further aclaration.
#4 | ||
Carlos Rubio Abujas
Rep Power: 9 |
volScalarField A ( IOobject ( "B", // This is label asigned to the object in the register. runTime.timeName(), // This is the place where the object will be saved mesh, // This is the object which will act as register. IOobject::NO_READ, // Reading options (in case it founds a file named "B" do not read it") IOobject::AUTO_WRITE // Writing options ), mesh // This is used to "size" the field to mesh domain. ); Quote:
volScalarField& AA = mesh().lookupObject<volScalarField>("B"); So now I can access the same data, as register is referring to the same memory address, in a different code. Think as AA as an "alias" to this memory address. The name of this "alias" is only important inside the piece of code itself. Other codes can handle the same data, with different aliases. Inside OF there are plenty of code files, some of them rely on the files you mentioned (fvScheme, fvSolution...). So it uses the register as a way to share this data accross the different parts. I hope that makes it a little bit more clear. |
June 2, 2020, 11:10 |
Rep Power: 5 |
Hi Crubio,
Thank you for the kind replies. It really helps. My code and cases can run successfully now. Very appreciate the help! Regards, Yongqiang |
OpenFOAM class declaration error with volScalarField | raunakbardia | OpenFOAM Programming & Development | 0 | June 2, 2019 15:46 |
Newly defined volScalarField "indexT" has different array ranges in paraview | nero235 | OpenFOAM Programming & Development | 1 | September 30, 2016 11:57 |
How to output user-defined volScalarField that paraFoam can read? | keepfit | OpenFOAM Programming & Development | 5 | February 7, 2014 07:50 |
Runtime modification of a volScalarField | Scofield | OpenFOAM Programming & Development | 4 | October 1, 2013 08:31 |
Definition of a linear function as volScalarField | titio | OpenFOAM Running, Solving & CFD | 1 | October 3, 2010 16:51 |
