Problem with fvm::laplacian(A,sqrt(k))
Old   May 2, 2020, 23:29
Default Problem with fvm::laplacian(A,sqrt(k))
TWB
quarkz is on a distinguished road
I've trying to modify the Turbulent kinetic energy equation.
Basically, for some reasons, I need to modify from e.g.:
fvm::laplacian(A,k)
to
fvm::laplacian(A/sqrt(k),sqrt(k))
where the full eqn is:
tmp<fvScalarMatrix> kEqn
        fvm::ddt(alpha, rho, k)
      - fvm::laplacian(A/sqrt(k),sqrt(k))
The errors I got are:
error: no matching function for call to ‘laplacian(Foam::tmp<Foam::GeometricField<dou ble, Foam::fvPatchField, Foam::volMesh> >, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >)’
/opt/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude/fvmLaplacian.C:47:1: note: template argument deduction/substitution failed:
In file included from ../turbulenceModels/lnInclude/kOmegaSSTF.H:194:0,
If I change to explicit:
fvc::laplacian(A/sqrt(k),sqrt(k))
Then there is no problem.
But if I want it to be implicit, is there any way?
Thanks in advance.
quarkz is offline   Reply With Quote
Old   May 3, 2020, 16:59
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
to use fvm for sqrt(k), the governing equation should br sqrt(k) rather than k.
Is this a source term which can be put on the right hand side?
HPE is offline   Reply With Quote
Old   May 3, 2020, 21:04
TWB
Sorry, I think I made a mistake. I am solving for k, so I'm actually computing fvc::laplacian(A/sqrt(k),sqrt(k)) on the RHS as explicit.
Thanks anyway!
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
