May 21, 2020, 12:26 |
How to implement a new boundary condition
Rep Power: 6 |
Hi everyone,
I need your help! I thank you in advance for spending your time. I am a new user of openFoam and I am not very experienced. I need to build a new BC on outlet pressure. The pressure that I must impose depends on the value of the outlet flow rate. Can you give me some indication of how to start? Or is there something similar already implemented? Last edited by Neb; May 22, 2020 at 03:40. |
May 22, 2020, 02:49 |
alexander thierfelder
Rep Power: 6 |
Hi I have some links for you:
A whole bunch of examples and a good start for OF programming, also BC: http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/ and https://wiki.openfoam.com/index.php?...eeks%22_series I also like the tutorials of wolfdynamic, there are some good examples for codeStream and the use in BC: http://www.wolfdynamics.com/images/O...g/openfoam.pdf http://www.wolfdynamics.com/tutorial...out=edit&id=50 Search also for forum post like: Custom Boundary Condition with OpenFOAM That is by no means complete, but a good start I think. |
May 22, 2020, 03:28 |
Rep Power: 6 |
May 22, 2020, 03:39 |
Rep Power: 6 |
Thanks Superkelle, you have been very kind! this is so much material!
S. |
May 22, 2020, 04:36 |
Herpes Free Engineer
Rep Power: 12 |
Some of the links below may also help. Good luck!
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 22, 2020, 05:17 |
Rep Power: 6 |
Thanks HPE, you are very kind!
flow rate, new bc, outlet, pressure |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Divergence after implement nonreflecting boundary condition | fireflies | Main CFD Forum | 0 | October 23, 2014 10:16 |
How to implement heat flux boundary condition as function of time | baran_foam | OpenFOAM Running, Solving & CFD | 3 | September 15, 2014 00:28 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
