April 12, 2019, 10:24 |
Event counter overflowed -> MPI crash
Rep Power: 15 |
I've run into a problem that I can't seem to find any information on here, and is outside my area of knowledge. I'm working on a turbulent inflow generation code and am testing it out now. It (seems like it) works fine, however when I run in parallel, after running for awhile I get the following warning:
--> FOAM Warning : From function Foam::label Foam::objectRegistry::getEvent() const in file db/objectRegistry/objectRegistry.C at line 221 Event counter has overflowed. Resetting counter on all dependent objects. Code:
*** An error occurred in MPI_Waitall *** reported by process [3615162369,7] *** on communicator MPI_COMM_WORLD *** MPI_ERR_TRUNCATE: message truncated *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) Has anyone ran into this type of problem before, or have any suggestions on how to solve it? This is using foam-extend-4.1. Last edited by amanbearpig; April 12, 2019 at 10:25. Reason: Specifying OpenFOAM version |
June 21, 2020, 02:08 |
Chaewoong Ban
Rep Power: 12 |
Do you have solved this problem? I also struggle with similar problem..
Running in serial and in parallel with few nodes are fine. However, in parallel with many nodes leads to crash or stuck somewhere. (The solver i used is interDyMFoam and fe41 is version of OF) |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
Event counter in OpenFOAM | adhiraj | OpenFOAM | 3 | February 10, 2012 11:56 |
Sgimpi | pere | OpenFOAM | 27 | September 24, 2011 07:57 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
