Reading a value from fvSolution into custom simpleFoam |
Klaus
Rep Power: 22 ![]() |
I want to use an additional value in my custom simpleFoam solver but am not able to read it from the fvSolution dictionary "SIMPLE" section.
The default value should be 4. I tried: Code:
const int A_ = controlDict_.lookupOrDefault<label> ("A", 4); Code:
SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; A 4; } |
Chris DeGroot
Rep Power: 17 ![]() |
It looks like you are trying to read the value from controlDict, not fvSolution.
Klaus
It's not that simple, I tried fvSolution too but the problem seems to be related to the definition of the dictionary to be accessed. Unfortunately I can only find examples related to custom dictionaries, not the standard ones.
Chris DeGroot
Fair enough, but aribitrarily trying to read it from the wrong dictionary is sure to fail!
Klaus
I tried different ways and dictionaries including a custom dictionary. I did it when I used pervious versions of OpenFOAM. Maybe something changed with OF7.
Chris DeGroot
Check out the class definition for fvSolution:
Class Foam::fvSolution Description Selector class for finite volume solution solution. fvMesh is derived from fvSolution so that all fields have access to the fvSolution from the mesh reference they hold. Code:
fvSolution(static_cast<const objectRegistry&>(*this)) |
Klaus
This is, how it worked:
const word dictName("fvSolution"); IOdictionary solutionDict ( IOobject ( dictName, runTime.system(), //folder where the fvSolution file is located runTime, IOobject::MUST_READ ) ); dictionary& mysimplesubDict = solutionDict.subDict("mySIMPLE"); // subsection where the values are stored int A1_ = (mysimplesubDict.lookupOrDefault<label>("A1", 2)); int A2_ = (mysimplesubDict.lookupOrDefault<label>("A2", 2)); |
Parallel Block Size Issue | ChiefSeaBiscuit | CONVERGE | 5 | July 22, 2016 14:03 |
OpenFOAM floating point Error | upuli | OpenFOAM Programming & Development | 5 | June 20, 2016 03:19 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
