Patch normals patch().nf() in basicSymmetryFvPatchField
Like Tree1Likes
  • 1 Post By jherb
Old   August 28, 2020, 09:04
Default Patch normals patch().nf() in basicSymmetryFvPatchField
Saeed Salehi
salehi144 is on a distinguished road
Dear Foamers!
I am using surfaceSlipDisplacementFvPatchFields BC. It appears that it inherits from the slip BC and the slip BC inherits from the basicSymmetry. So it all comes down to the evaluate function in the basicSymmetry. This evaluate function simply eliminate the normal component to the patch by:
    tmp<vectorField> nHat = this->patch().nf();
    const Field<Type> iF(this->patchInternalField());
    Field<Type>::operator=
        (iF + transform(I - 2.0*sqr(nHat), iF))/2.0
    transformFvPatchField<Type>::evaluate();
It can be seen that the normal vector to the patch, patch().nf(), is first read (the red line) and then the normal component of the quantity of interest is removed.
Now, I have a case where the mesh is changing through time and OpenFOAM naturally updates the patch().nf() in each time-step. However, I specifically need to fix patch().nf(). In other words, I need to always read the patch normals, of the initial mesh (i.e., the mesh in the constant folder and not the mesh in the time folders).
Any ideas or help would be much appreciated.
Saeed
salehi144 is offline   Reply With Quote
Old   August 28, 2020, 18:36
Joachim Herb
jherb is on a distinguished road
You could add a vectorField to a modified boundary class and initialize it within the constructor. But for this to be restart-enabled, you have to store this field in the write method of the boundary condition and read it if available in the constructor (the one with dict in the parameter list).
salehi144 likes this.
jherb is offline   Reply With Quote
Old   August 31, 2020, 09:24
Saeed Salehi
Thank Joachim for the answer.
That seems a good idea. I will give it a try and let you know.
Saeed
Plotting Surface tension force with interfoam Mahmoud_aboukhedr OpenFOAM Programming & Development 5 December 1, 2016 08:37
2D train nose profile analysis Jchan88 FLUENT 2 April 30, 2013 00:15
