Cell volume and face area calculation
Old   August 18, 2015, 13:28
Default Cell volume and face area calculation
Richard Vega
richard_vega is on a distinguished road
Is there a simple way to obtain a list that has the volume of each cell in a mesh along with a list that has the area of each face in a mesh?
richard_vega is offline   Reply With Quote
Old   August 18, 2015, 13:37
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1. V method in fvMesh (http://foam.sourceforge.net/docs/cpp...9d5006af5644e5)
2. Sf method in fvMesh (http://foam.sourceforge.net/docs/cpp...121219b4ce84f9)
alexeym is offline   Reply With Quote
Old   August 18, 2015, 13:54
Richard Vega
Thank you for the quick reply. I probably should have stated somewhere in that question that I have no experience programming in OpenFOAM. The extent of my experience is using standard solvers and utilities, so the links did not mean a while lot to me. Could you add a bit more explanation on how I could use these functions?
Old   August 18, 2015, 14:04
Alexey Matveichev
Obviously, it depends on where you would like to use them.
But basically if you have mesh object or type fvMesh (usually you have it in solvers and in most of utilities), then if you would like to iterate over cell volumes, you can use something like:
forAll(mesh.V(), idx)
    Info<< "Volume of cell with index " << idx << " is " << mesh.V()[idx] << end;
Maybe it would be better, if you post why do you need volumes of cells and areas of faces.
Old   August 18, 2015, 14:10
Default why I need them...
Richard Vega
I am using OpenFOAM only as a pre and post processor to my code, which is written in C/OpenCL. Somewhere in my code, I am calculating the volumes and areas and I am getting some strange results that I believe are a result of the 5 digit precision in the points file. I wanted to use OpenFOAM to calculate the volumes and areas to see if this a bug in my code, or indeed the precision issue I am suspecting. Thus, I was hoping for sort of a one-liner that would generate a file called "volumes," but I guess no dice. I will try your suggestion tonight.
Old   August 18, 2015, 14:46
Alexey Matveichev
If you just need to look at the list of volumes you can use
Info << mesh.V() << endl;
Or you can use utility from attached archive, it will write cell volumes in volumes.dat file and face areas into areas.dat file.
File Type: gz write_cell_volumes_and_face_areas.tar.gz (759 Bytes, 181 views)
Old   April 7, 2021, 06:08
Jingna Pan
J. Pan is on a distinguished road
Hi Alexey,
I tried to compile the utility but encountered the following error. I appreciate if you could give any hints. FYI: I am using openfoam 5 and Ubuntu 20.04.
write_cell_volumes_and_face_areas.cpp:6:10: fatal error: OFstream.H: No such file or directory
6 | #include "OFstream.H"
compilation terminated.
J. Pan is offline   Reply With Quote
face area cell volume
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
