Accessing transportProperties from coded functionObject
Old   April 19, 2021, 11:35
Default Accessing transportProperties from coded functionObject
Shibi is on a distinguished road
Hello to all,
I would like to create a custom functionObject to use in laplacianFoam.
For this purpose, I need the parameter DT in the dictionary transportProperties.
I have:
functions
    myCodedFunction
        type coded;
        libs (utilityFunctionObjects);
        writeControl runTime;
        writeInterval $writeInterval;
        // Name of on-the-fly generated functionObject
        name test;
        codeWrite
            // Lookup for T
            const volScalarField& T = mesh().lookupObject<volScalarField>("T");
            // Gets the DT coefficient from
          const dictionary& transportProperties = mesh().lookupObject<IOdictionary>
             "transportProperties"
            const scalar alpha (transportProperties.getScalar("DT"));
            Info << "Alpha is: " << alpha << endl;
However, I get the error:
    request for dictionary transportProperties from objectRegistry region0 failed
    available objects of type dictionary are
4(fvSchemes fvOptions fvSolution data)
It the transportProperties not created yet? Am I looking for it in a wrong manner?
Shibi is offline   Reply With Quote
Old   April 19, 2021, 15:26
clapointe is on a distinguished road
A quick look at the laplacianFoam code suggests that the transportProperties dictionary is only created (inside an if statement) if DT doesn't exist (otherwise it's read). So to guess at a fix you could create a custom version of laplacianFoam in which you force the creation of the dictionary without the if statement, or create a dummy/copy of it inside your function object like :
    IOdictionary dummyTransportProperties //ensure the original isn't duplicated
        IOobject
            "transportProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
    //then read from dict
Note that I've not tested the above code, but hopefully it will lead you in the right direction.
Caelan
Public git repository : https://github.com/clapointe2011/public
clapointe is offline   Reply With Quote
accessing 0 time directory in coded functionObject JM27 OpenFOAM Programming & Development 3 May 26, 2023 16:50
Cannot find functionObject file residuals vava10 OpenFOAM Pre-Processing 2 November 14, 2020 12:21
accessing 0 time directory in coded functionObject JM27 OpenFOAM Post-Processing 0 November 21, 2018 08:41
Coded FunctionObject to calculate distance to axis? Nothing written be_inspired OpenFOAM Programming & Development 0 February 22, 2018 18:23
codeInclude in coded function in controlDict, and yPlus LuisAlberto OpenFOAM Programming & Development 4 August 18, 2015 12:48
