How to automatically switch boundary conditions |
May 31, 2021, 14:22 |
Nursultan
Rep Power: 5 |
Hello everyone,
I need automatically switch inlet and outlet conditions in the way that I described below. 1st iteration: Initial conditions: Pressure (P) (experiment value) inlet -> Mass flow rate (Q)(outlet) Result: Mass flow rate (Q) (calculated) inlet -> P and Q (calculated) at outlet then we need to put calculated P values from the outlet of 1st iteration to the outlet initial conditions of 2nd iteration 2nd iteration: Initial conditions: Mass flow rate (Q) (experiment value) inlet -> Pressure (P) (1st iteration calculated) (outlet) Result: Pressure (P) (calculated) inlet -> Mass flow rate Q (calculated) at outlet then we need to put calculated Q values from the outlet of the 2nd iteration to the outlet initial conditions of 3rd iteration 3rd iteration: Initial conditions: Pressure (P) (experiment value) inlet -> Mass flow rate (Q) (2nd iteration calculated) (outlet) Result: Mass flow rate (Q) (calculated) inlet -> P and Q (calculated) at outlet and etc. How to program such kind of algorithm in OpenFOAM? Maybe in bash or python script. Replies will be very helpful. I appreciate every response. Kind regards, Nursultan |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
CGNS Boundary conditions using SU2 | denzell | SU2 | 3 | July 9, 2018 05:58 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
