Interpolation in OpenFoam
Like Tree4Likes
  • 3 Post By hjasak
  • 1 Post By s.v
Old   July 27, 2008, 01:51
Default Interpolation in OpenFoam
srinath
srinath is on a distinguished road
Hello
I was reading Hrv's thesis and have a couple of doubts on the interpolation routine in OpenFoam
For the NVD schemes, there is an expression on page 109, which gives
\phi c \tilda = 1 - (gradphi)f.d/(2*grad phi)c.d
And a nice algorithm to give the value of phi on the face, using blended/gamma differencing.
But how do we calculate (grad phi)c?
Suppose i had rho at cell centers and wanted to obtain a limited value of rho on the surface, what would i do?
Should i use a least squared approach to find (grad phi)c?
Also i can't seem to find a formulation of TVD using slope limiters on unstructured grids.
Could someone please help me on this?
Thanks
Srinath
srinath is offline   Reply With Quote
Old   July 30, 2008, 05:27
Default Yes. Both TVD and NVD are cal
Hrvoje Jasak
Yes. Both TVD and NVD are calculated the way I described in the original Gamma paper:
@Article{Jasak:GAMMAPAPER,
author = {Jasak, H. and Weller, H.G. and Gosman, A.D.},
title = {High resolution NVD differencing scheme for
arbitrarily unstructured meshes},
journal = {Int. J. Numer. Meth. Fluids},
year = 1999,
volume = 31,
pages = {431-449}
Here's the code (below). As you can see, it uses the cell gradient and a face gradient (actually a difference across the face). For the cell gradient, you can use whatever you like: Gauss gradient will do. The code implements phict for the NVD and r for TVD.
Enjoy,
Hrv
scalar phict
const scalar faceFlux,
const vector& phiP,
const vector& phiN,
const tensor& gradcP,
const tensor& gradcN,
const vector& d
) const
vector gradfV = phiN - phiP;
scalar gradf = gradfV & gradfV;
scalar gradcf;
if (faceFlux > 0)
gradcf = gradfV & (d & gradcP);
else
gradcf = gradfV & (d & gradcN);
// Stabilise for division
gradcf = stabilise(gradcf, VSMALL);
return 1 - 0.5*gradf/gradcf;
scalar r
const vector& phiP,
const vector& phiN,
const vector& d
) const
scalar gradcf;
if (faceFlux > 0)
else
gradf = stabilise(gradf, VSMALL);
return 2*(gradcf/gradf) - 1;
Hrvoje Jasak
Old   July 30, 2008, 08:08
Default Thanks for the reference Profe
srinath
Thanks for the reference Professor Jasak, this scheme seems so much better computationally than something like ENO.
For the cell gradient, when you say Gauss gradient, do you mean
integral(grad (phi)dV) = \sigma dS * phi_face
Where dS is the outward pointing Area vector?
But in that case how do we get phi_face?
Is it ok to use the cell centre averages of the 2 cells sharing that face?
Regards
Srinath
Old   July 30, 2008, 10:44
Default Yes, correct: you interpolate
Hrvoje Jasak
Yes, correct: you interpolate from the cell centre values. Remember how the scheme says Gauss linear - it is the linear that tells you how to interpolate (=linear interpolation}. You could of course do Gauss harmonic as well, you can guess what that does.
Enjoy,
Hrv
Hrvoje Jasak
Old   July 31, 2008, 02:42
Default Thanks Professor Jasak That
srinath
That clears up this issue totally
Regards
Srinath
Old   September 4, 2008, 07:01
Default Hi, I'm testing discretiza
ville vuorinen
ville is on a distinguished road
I'm testing discretization schemes for LES and have come up with the following picture on a
scalar pulse that is originally:
c = 1, when 0.2m < x < 0.7m
c = 0, elsewhere
and the pulse is advected to the right with velocity 1m/s. The Courant number is 0.1 and time integration is backward. The Gamma scheme is
the Gamma01 scheme.
A couple of questions about Gamma schemes in
OpenFOAM in general:
1) I've noted that the smaller I make the value
0<= psi <= 1, the larger overshoots I make.
What is the connection between psi and the parameter beta given in the above-mentioned
paper (Jasak et al.)? I seached the code
(as given above and related files) but
could not find a connection... The paper tells
us that typically beta = 0.1 is the lower limit.
2) What is the difference between the GammaV
scheme and the Gamma scheme? I can use both
for velocity.. So, where does the "V" come into
play?
Regards,
Ville
ville is offline   Reply With Quote
Old   May 26, 2014, 02:26
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by ville View Post
play?
Regards,
Ville
Do you got the answer?
Tushar@cfd is offline   Reply With Quote
Old   June 6, 2021, 15:52
s.v
s.v
s.v is on a distinguished road
Hi Everyone:
I know this is an old thread but this might be useful for others.
Regarding Ville's first question -- psi = 2*Beta (as far as I understand).
So to avoid the "switching" instability discussed by Jasak et al. in their original Gamma scheme paper (https://citeseerx.ist.psu.edu/viewdo...=rep1&type=pdf) we would need to have psi>=0.2.
This is discussed in my PhD thesis (https://drum.lib.umd.edu/handle/1903/21883) on page 32. In my thesis psi is called "k".
Cheers ....
wo315 likes this.
s.v is offline   Reply With Quote
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
2D-Interpolation Don Tron Main CFD Forum 3 October 30, 2003 03:40
