access the values on a patch with its faceID
Old   September 11, 2021, 07:16
Smile access the values on a patch with its faceID
FarhadZDH is on a distinguished road
Hi foamers;
I have a basic problem!
I want to smooth a variable on a boundary patch. so it is important to access the boundary faces in order.
This is what I did so far:
I use boundaryField() member function and forAll loop to handle the faces on a patch. the problem is that the faces are not necessarily consecutive.
forAll(variable.boundaryField()[patchID],ii)
Info << variable.boundaryField()[patchID][ii].y() << endl;
Another thing that I am testing is to get the start face of the patch then clearly I have the face id of the rest, that way I access the faces in order, I guess. At this point, I wonder how I can access the face value by using the faceID.
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
label faceId_start = cPatch.start() ;
forAll(cPatch, faceI)
// index of each face
label faceID = faceId_start +faceI;
// Now how could I access a variable value at faces using faceID
Thanks in advance!
PS: I am searching the resources simultaneously
I used blockMesh and snappyHexMesh to create my geometry.
FarhadZDH is offline   Reply With Quote
faceid, patch, polypatch
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 18:10
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
