February 9, 2011, 05:04 |
Residual definition of OpenFoam
Hi Dear Foamers,
I am a new guy of OpenFOAM, and I just run the test case of pitzDaily in the OpenFoam tutorial, but with 20000 iterations, Because it does not reach the tolerance 1e-6 yet. Anyway, I found that the initial residual has huge oscillation before it reach the tolerance(actually somewhere about 3e-5). So I want to figure out i) what is the type of the initial residual ii) why it behaves like this. The first thing I do is to check the code (instead of searching answers from the form......). I went directly to the solver PCG and find the definition of the initial residual and finial residual, which will be like this: solverPerf.initialResidual() = gSumMag(rA)/normFactor; solverPerf.finalResidual() = solverPerf.initialResidual(); Then I found the definition of the norm Factor: //------------------------------------------------------- Foam::scalar Foam::lduMatrix::solver::normFactor ( const scalarField& psi, const scalarField& source, const scalarField& Apsi, scalarField& tmpField ) const { // --- Calculate A dot reference value of psi matrix_.sumA(tmpField, interfaceBouCoeffs_, interfaces_); tmpField *= gAverage(psi); return gSum(mag(Apsi - tmpField) + mag(source - tmpField)) + matrix_.small_; // At convergence this simpler method is equivalent to the above // return 2*gSumMag(source) + matrix_.small_; } //------------------------------------------------------------- and also the MACRO definitioin of gSumMag: //------------------------------------------------------------- #define G_UNARY_FUNCTION(returnType, gFunc, func, rFunc) \ \ template<template<class> class Field, class Type> \ returnType gFunc(const FieldField<Field, Type>& f) \ { \ returnType res = func(f); \ reduce(res, rFunc##Op<Type>()); \ return res; \ } \ TMP_UNARY_FUNCTION(returnType, gFunc) G_UNARY_FUNCTION(Type, gMax, max, max) G_UNARY_FUNCTION(Type, gMin, min, min) G_UNARY_FUNCTION(Type, gSum, sum, sum) G_UNARY_FUNCTION(scalar, gSumMag, sumMag, sum) #undef G_UNARY_FUNCTION //---------------------------------------------------------------- Actually I got stuck here....... literally speaking, what I want is just to figure out what kind of norm does PCG (or other solvers ) use, and now I messed all the things up...... I GUESS it was L2 norm or Root Mean Square (RMS) because to my knowledge, only L2 norm is defined as SumFunc()/OtherSumFunc, but I do not know if it was correct. So my question will be what is the initial residual does PCG use? And why after 20000 iterations, oscillation occurs? Of couse I also want to understand what does these codes do, especially the macro part, which is really hard for me to understand. If someone can explain sth. about this, I'd really appreciate it! Thanks for any scanner forward! BR, ------------ bodyouareboy |
March 13, 2011, 13:30 |
Rep Power: 15 |
Hi all!
Does anyone has an answer regarding the question of boddyouareboy? I'm also interested to figure out what type of residual is actually being calculated by OF. Thank you! L1011 |
March 14, 2011, 04:39 |
#3 | |
Anton Kidess
Rep Power: 29 |
March 15, 2011, 03:08 |
Rep Power: 16 |
Hello together,
as far as I understood it, it is a the L1-nrom since the magnitudes of the residual-vector are summed up. But what still is a kind of miracle to me is the role of the normfactor. I don't see what it is necessary for. |
May 13, 2011, 08:24 |
The normalization is required, because you variables can vary in different ranges, so it is a kind of unifying the residuals for different scales in your equations.
But actually a found an issue, when the tol parameter is not so representative than relTol. For example in my case, for RANS simulation when I switch to the 2nd order, for some equations a strong source terms are produced due to non-orthogonal corrections in sqewed cells. If you analyze the line: Code:
// At convergence this simpler method is equivalent to the above // return 2*gSumMag(source) + matrix_.small_; I tried to get from Code:
gSum(mag(Apsi - tmpField) + mag(source - tmpField)) + matrix_.small_; Code:
// At convergence this simpler method is equivalent to the above // return 2*gSumMag(source) + matrix_.small_; The solution is either to set tol to something around 1e-8...1e-10 with relTol 0, or use tol 1e-12 for all equations tuning the level of accuracy by e.g. relTol 0.001. So thus you define to improve your residuals for 3 orders. relTol can vary base are you making steady or transient calculations.
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at Last edited by makaveli_lcf; May 13, 2011 at 11:38. |
March 16, 2017, 08:28 |
Fredi Cenci
Rep Power: 9 |
Hey guys,
I know the post is old but I would like to clarify some questions about residuals. 1- As I understood residual is the difference between a field (phi) from one iteration to another, right? so is it Initial Residual? Final Residual? 2 -Can someone tell me how to get L1, L2 and L infinity from the log file? Equations are attached. 3 -If I decrease the tolerance of p,U then the final residual will be lower, right? Is it possible? I dont know what type of residuals openfoam ii giving me on log file.. Code:
Time = 0.02 Courant Number mean: 0.107298 max: 1.36175 DILUPBiCG: Solving for Ux, Initial residual = 0.959413, Final residual = 5.4585e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.317289, Final residual = 8.53016e-07, No Iterations 3 DICPCG: Solving for p, Initial residual = 0.0109834, Final residual = 0.00109738, No Iterations 112 DICPCG: Solving for p, Initial residual = 0.336017, Final residual = 0.0308665, No Iterations 17 time step continuity errors : sum local = 0.000179841, global = 1.53469e-07, cumulative = 1.16262e-07 DICPCG: Solving for p, Initial residual = 0.260022, Final residual = 0.0227987, No Iterations 23 DICPCG: Solving for p, Initial residual = 0.133745, Final residual = 8.55957e-07, No Iterations 180 time step continuity errors : sum local = 2.53382e-09, global = -4.25928e-11, cumulative = 1.16219e-07 delta (Phi) is the local change of the flow quantity Phi. Np is the mesh total nodes. Thanks [Moderator note: merged 3 posts, one moved from L0, L1, L2 ,Linf error norms] Last edited by wyldckat; April 30, 2017 at 11:36. Reason: merged 3 posts on the same topic |
March 18, 2017, 12:07 |
function
Fredi Cenci
Rep Power: 9 |
I didnt find any function to calculate the change of a variable (U,p,omega,k..) between consecutive time steps in all cells.
May 22, 2023, 04:56 |
Anais Messaoudi
Rep Power: 2 |
Hi, does anyone have answers to fredicenci's questions please?
Thanks! Anais M |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
