EpsilonWallFunction crashes with two connected walls
Old   October 26, 2021, 05:46
Default EpsilonWallFunction crashes with two connected walls
Bibill is on a distinguished road
Dear all,
I am implementing an own EpsilonWallFunction for a k-epsilon simulation. Inside the WF I would like to compute both the strain rate and vorticity invariants.
Here is the structure of the code :
void Foam::MyepsilonWallFunctionFvPatchScalarField::calculate
    const turbulenceModel& turbModel,
    const List<scalar>& cornerWeights,
    const fvPatch& patch,
    scalarField& G0,
    scalarField& epsilon0
    const volVectorField& Ut = turbModel.U();
    /* Strain rate invariant */
    volSymmTensorField S = symm(fvc::grad(Ut));
    /* Vorticity invariant */
    volTensorField W = skew(fvc::grad(Ut));
If we consider a rectangular wind tunnel, the WF works well for a single wall (let's say the ground), for two different and unconnected walls (e.g the ground and the top wall) but it crashes for two connected walls (e.g the ground and a side wall).
The errors are:
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.000410734772, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.999853259, Final residual = 0.000909577149, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 0.999796967, Final residual = 0.000793379745, No Iterations 4
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.000988755628, No Iterations 23
time step continuity errors : sum local = 4.17199017e-05, global = 1.25994915e-05, cumulative = 1.25994915e-05
[c06c4f9bf5aa:13379] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[c06c4f9bf5aa:13379] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
[c06c4f9bf5aa:13385] *** An error occurred in MPI_Waitall
[c06c4f9bf5aa:13385] *** reported by process [1137901569,0]
[c06c4f9bf5aa:13385] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0
[c06c4f9bf5aa:13385] *** MPI_ERR_TRUNCATE: message truncated
[c06c4f9bf5aa:13385] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[c06c4f9bf5aa:13385] ***    and potentially your MPI job)
NB:
• After some tests, the error occurs at the gradient computation line;
• It runs in serial;
• It runs for 5 processors but not for 15;
I would truly appreciate any help or comments!
thanks in advance!
Bibill is offline   Reply With Quote
openfoam 7, wall function
[ICEM] Defining Interfaces and Splitting Internal Walls ICEM-FLUENT pmtgt ANSYS Meshing & Geometry 8 June 4, 2021 07:15
[snappyHexMesh] Reading checkMesh output streamline90 OpenFOAM Meshing & Mesh Conversion 4 October 28, 2019 09:52
twoPhaseEulerFoam bubble column crashes due to problems at outlet region hester OpenFOAM Running, Solving & CFD 4 May 18, 2016 10:20
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
