Implementing the temperature equation in interPhaseChangeFoam (OpenFOAM 8 version)
Old   June 24, 2022, 06:35
Post Implementing the temperature equation in interPhaseChangeFoam (OpenFOAM 8 version)
JD_PM is on a distinguished road
I want to implement a simplified version of the temperature equation (see here: https://ibb.co/RzjbBnj D_T is the effective turbulent thermal diffusivity).
I am using version 8 of OpenFOAM
This is how I proceeded:
I copy-pasted the interPhaseChangeFoam solver (path $FOAM_SOLVERS/multiphase/interPhaseChangeFoam) to my working directory and then changed its name to interPhaseChangeThermalFoam.
I want to keep the default cavitation models (just as a side note: I implemented the ZGB cavitation model, besides the three default ones) available so I can't just erase the phaseChangeTwoPhaseMixtures.
There is a solver called compressibleInterFoam ($FOAM_SOLVERS/multiphase/compressibleInterFoam) which contains a folder called twoPhaseMixtureThermo. The idea was to combine this folder with phaseChangeTwoPhaseMixtures. To do so I copy-pasted the .C and .H files of twoPhaseMixtureThermo to phaseChangeTwoPhaseMixtures.
Once I did that I renamed phaseChangeTwoPhaseMixtures as twoPhaseMixtureThermo.
Next I attach the relevant files regarding twoPhaseMixtureThermo
twoPhaseMixtureThermo/Make/files
twoPhaseMixtureThermo/phaseChangeTwoPhaseMixture.C
twoPhaseMixtureThermo/phaseChangeTwoPhaseMixtureNew.C
Kunz/Kunz.C
Merkle/Merkle.C
SchnerrSauer/SchnerrSauer.C
ZGB/ZGB.C
twoPhaseMixtureThermo.C
LIB = $(FOAM_USER_LIBBIN)/libtwoPhaseMixtureThermo
twoPhaseMixtureThermo/Make/options
EXE_INC = \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/interfaceProperties/lnInclude \
	-I$(LIB_SRC)/transportModels/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/incompressibleTwoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/twoPhaseModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude \
	-I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
    -lfluidThermophysicalModels \
    -limmiscibleIncompressibleTwoPhaseMixture \
    -lspecie \
    -ltwoPhaseMixture \
    -linterfaceProperties \
    -lfiniteVolume
Next I attach the relevant files regarding interPhaseChangeThermalFoam
interPhaseChangeThermalFoam.C
#include "fvCFD.H"
#include "dynamicFvMesh.H"
#include "CMULES.H"
#include "subCycle.H"
#include "interfaceProperties.H"
#include "phaseChangeTwoPhaseMixture.H"
#include "kinematicMomentumTransportModel.H"
#include "pimpleControl.H"
#include "fvOptions.H"
#include "CorrectPhi.H"
int main(int argc, char *argv[])
    #include "postProcess.H"
    #include "setRootCaseLists.H"
    #include "createTime.H"
    #include "createDynamicFvMesh.H"
    #include "createDyMControls.H"
    #include "initContinuityErrs.H"
    #include "createFields.H"
    #include "initCorrectPhi.H"
    #include "createUfIfPresent.H"
    turbulence->validate();
    #include "CourantNo.H"
    #include "setInitialDeltaT.H"
    Info<< "\nStarting time loop\n" << endl;
    while (pimple.run(runTime))
        #include "readDyMControls.H"
        // Store divU from the previous mesh so that it can be mapped
        // and used in correctPhi to ensure the corrected phi has the
        // same divergence
        volScalarField divU("divU0", fvc::div(fvc::absolute(phi, U)));
        #include "alphaCourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
            if (pimple.firstPimpleIter() || moveMeshOuterCorrectors)
                mesh.update();
                if (mesh.changing())
                    gh = (g & mesh.C()) - ghRef;
                    ghf = (g & mesh.Cf()) - ghRef;
                    if (correctPhi)
                        // Calculate absolute flux
                        // from the mapped surface velocity
                        phi = mesh.Sf() & Uf();
                        #include "correctPhi.H"
                        // Make the flux relative to the mesh motion
                        fvc::makeRelative(phi, U);
                    mixture.correct();
                    if (checkMeshCourantNo)
                        #include "meshCourantNo.H"
            divU = fvc::div(fvc::absolute(phi, U));
            surfaceScalarField rhoPhi
                IOobject
                    "rhoPhi",
                    runTime.timeName(),
                    mesh
                mesh,
                dimensionedScalar(dimMass/dimTime, 0)
            #include "alphaControls.H"
            #include "alphaEqnSubCycle.H"
            mixture.correct();
            #include "UEqn.H"
	    #include "TEqn.H" /adding temperature equation
            // --- Pressure corrector loop
            while (pimple.correct())
                #include "pEqn.H"
            if (pimple.turbCorr())
                turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
TEqn.H
#include "fvCFD.H"
#include "CMULES.H"
        // same divergence
        runTime++;
                mesh.update();
                    if (correctPhi)
                    mixture.correct();
                IOobject
                    "rhoPhi",
                    runTime.timeName(),
                    mesh
                mesh,
            mixture.correct();
            #include "UEqn.H"
			#include "TEqn.H"
                #include "pEqn.H"
        runTime.write();
            << nl << endl;
    //Adding temperature equation
    /*solve
        fvm::ddt(T) + fvm::div(phi,T) == fvm::laplacian(DT,T)
    return 0;
createFields.H
//read the thermal diffusivity constant from transportProperties
Info<< "Reading field p_rgh\n" << endl;
volScalarField p_rgh
    IOobject
        "p_rgh",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
Info<< "Reading field U\n" << endl;
volVectorField U
    IOobject
        "U",
        runTime.timeName(),
        mesh,
    mesh
//scalar field for the temperature
Info<< "Reading field T\n" << endl;
volVectorField T
    IOobject
        "T",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ, // Must read T from the latest time directory
        IOobject::AUTO_WRITE // Data will be written according to controlDict
    mesh
#include "createPhi.H"
Info<< "Creating phaseChangeTwoPhaseMixture\n" << endl;
autoPtr<phaseChangeTwoPhaseMixture> mixturePtr
    phaseChangeTwoPhaseMixture::New(U, phi)
phaseChangeTwoPhaseMixture& mixture = mixturePtr();
volScalarField& alpha1(mixture.alpha1());
volScalarField& alpha2(mixture.alpha2());
const dimensionedScalar& rho1 = mixture.rho1();
const dimensionedScalar& rho2 = mixture.rho2();
// Need to store rho for ddt(rho, U)
volScalarField rho
    IOobject
        "rho",
        runTime.timeName(),
        mesh,
        IOobject::READ_IF_PRESENT
    alpha1*rho1 + alpha2*rho2
rho.oldTime();
// Construct incompressible turbulence model
autoPtr<incompressible::momentumTransportModel> turbulence
    incompressible::momentumTransportModel::New(U, phi, mixture)
#include "readGravitationalAcceleration.H"
#include "readhRef.H"
#include "gh.H"
volScalarField p
    IOobject
        "p",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    p_rgh + rho*gh
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell
    p,
    p_rgh,
    pimple.dict(),
    pRefCell,
    pRefValue
if (p_rgh.needReference())
    p += dimensionedScalar
        "p",
        p.dimensions(),
        pRefValue - getRefCellValue(p, pRefCell)
    p_rgh = p - rho*gh;
mesh.setFluxRequired(p_rgh.name());
mesh.setFluxRequired(alpha1.name());
#include "createFvOptions.H"
However, when I compile twoPhaseMixtureThermo I get the following error
g++: error: I/software/alternate/opensource/openfoam.user/fc30/8/OpenFOAM-8/src/twoPhaseModels/interfaceProperties/lnInclude: No such file or directory
I do not get why, as lnInclude exists within my twoPhaseMixtureThermo directory.
There is an old thread asking the same question (Implementation of Temperature Eqn in InterPhaseChangeFoam) but it did not solve my issue
JD_PM is offline   Reply With Quote
"Temperature out of range" Problem with reactingFoam altinel OpenFOAM Running, Solving & CFD 6 December 28, 2023 12:53
How can temperature e treated as a passive scalar be used in transport equation? granzer OpenFOAM Running, Solving & CFD 3 June 6, 2021 16:35
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
