Coupling Openfoam solver and keras trained neutral network model |
March 11, 2022, 04:38 |
Ahmed Hafez
Rep Power: 7 |
I try to couple simpleFoam solver and keras neutral network trained model. Anyone have an idea to do so? the following link suggest to use frugally-deep header library or #include <Python.h> https://www.researchgate.net/publica...itutive_models I installed frugally-deep and check it is working with ordinary C++ program However when I try to implement the same in OpenFoam I got compilation error. Anyone have an idea how to utilize frugally-deep in openFoam or even have an alternative way to use keras trained model. below is added code to simpleFoam and the error Code:
........................... #include <fdeep/fdeep.hpp> int main(int argc, char *argv[]) { ......................... const auto model = fdeep::load_model("fdeep_model.json"); const auto result = model.predict( {fdeep::tensor(fdeep::tensor_shape(static_cast<std::size_t>(4)), std::vector<float>{1, 2, 3, 4})}); std::cout << fdeep::show_tensors(result) << std::endl; .......................... } Code:
In file included from /usr/local/include/fplus/fplus.hpp:21, from /usr/local/include/fdeep/common.hpp:31, from /usr/local/include/fdeep/fdeep.hpp:9, from adFoam.C:83: /usr/local/include/fplus/optimize.hpp: In lambda function: /usr/local/include/fplus/optimize.hpp:119:24: error: call of overloaded ‘sqrt(double&)’ is ambiguous 119 | return sqrt(acc); | ^ In file included from /usr/include/features.h:461, from /usr/include/x86_64-linux-gnu/c++/9/bits/os_defines.h:39, from /usr/include/x86_64-linux-gnu/c++/9/bits/c++config.h:528, from /usr/include/c++/9/cstdint:38, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/int16.H:40, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/int.H:40, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/label.H:42, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/labelList.H:44, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/UPstream.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/Pstream.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/parRun.H:39, from /usr/lib/openfoam/openfoam2106/src/finiteVolume/lnInclude/fvCFD.H:4, from adFoam.C:77: /usr/include/x86_64-linux-gnu/bits/mathcalls.h:143:1: note: candidate: ‘double sqrt(double)’ 143 | __MATHCALL (sqrt,, (_Mdouble_ __x)); | ^~~~~~~~~~ In file included from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/scalar.H:42, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/zeroI.H:30, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/zero.H:157, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/UList.H:51, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/List.H:46, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/labelList.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/UPstream.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/Pstream.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/parRun.H:39, from /usr/lib/openfoam/openfoam2106/src/finiteVolume/lnInclude/fvCFD.H:4, from adFoam.C:77: /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/Scalar.H:184:11: note: candidate: ‘Foam::floatScalar Foam::sqrt(Foam::floatScalar)’ 184 | transFunc(sqrt) | ^~~~ /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/floatScalar.H:92:15: note: in definition of macro ‘transFunc’ 92 | inline Scalar func(const Scalar s) \ | ^~~~ In file included from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/scalar.H:43, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/zeroI.H:30, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/zero.H:157, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/UList.H:51, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/List.H:46, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/labelList.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/UPstream.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/Pstream.H:45, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/parRun.H:39, from /usr/lib/openfoam/openfoam2106/src/finiteVolume/lnInclude/fvCFD.H:4, from adFoam.C:77: /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/Scalar.H:184:11: note: candidate: ‘Foam::doubleScalar Foam::sqrt(Foam::doubleScalar)’ 184 | transFunc(sqrt) | ^~~~ /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/doubleScalar.H:93:15: note: in definition of macro ‘transFunc’ 93 | inline Scalar func(const Scalar s) \ | ^~~~ In file included from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/TimeState.H:41, from /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/Time.H:50, from /usr/lib/openfoam/openfoam2106/src/finiteVolume/lnInclude/fvCFD.H:6, from adFoam.C:77: /usr/lib/openfoam/openfoam2106/src/OpenFOAM/lnInclude/dimensionedScalar.H:68:19: note: candidate: ‘Foam::dimensionedScalar Foam::sqrt(const dimensionedScalar&)’ 68 | dimensionedScalar sqrt(const dimensionedScalar&); | ^~~~ make: *** [/usr/lib/openfoam/openfoam2106/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/simple2Foam.o] Error 1 |
March 11, 2022, 06:41 |
Josh Williams
Rep Power: 5 |
I think I recall trying Frugally deep but I could not wrap my head around it. In the end I ended up using keras2cpp. My supervisor's former student has a github repo where they use it and I found it pretty useful -- it is probably a good starting point for your implementation.
I find the keras2cpp to be much simpler (just one file that you include in compilation). It requires your network architecture in a json file, and then your weights as a .h5 file, which you can get like so: Code:
with open("./cpp_models/model_arch.json", "w") as fout: fout.write(model.to_json()) model.save("cpp_models/model_weights.h5") Then there is a file called `dump_to_simple_cpp.py' or something in the keras2cpp library which can be used to generate a model that can be read by the keras2cpp C++ code. I remember I had to make some modifications to this `dump' file as I think it had some issues recognising input layers, so I skipped them. There were a few other things specific to my case. |
March 11, 2022, 13:33 |
#3 | |
Ahmed Hafez
Rep Power: 7 |
Thank you for your reply ,I will check it.
