February 8, 2022, 12:59 |
Get cell volumes from lduSolver
Rep Power: 6 |
Hello to all,
I would like to know if there is a way to retrieve the a reference to the scalarField storing the cell volume of the mesh from an ldusolver. We could call the reference to the objectRegistry with: Code:
const objectRegistry& a = matrix().mesh().thisDb(); But I am getting the error: Code:
error: invalid use of incomplete type ‘const class Foam::objectRegistry’ |
February 9, 2022, 03:22 |
Mark Olesen
Rep Power: 40 |
The error means that objectRegistry was forward declared but not known completely in your code context.
Add an #include "objectRegistry.H" in your file. Nonetheless not sure why you want to get at cell volumes in such a roundabout manner - they are directly available from the mesh - don't have to lookup from the registry. |
February 9, 2022, 04:18 |
#3 | |
Rep Power: 6 |
How so? Inside the LDU solver, how can you get access to mesh volume? Something like: Code:
const fvMesh* myMesh = dynamic_cast<const fvMesh*>(&matrix().mesh()); const scalarField& V = myMesh->V(); Code:
#include "fvMesh.H" #include "volMesh.H" Code:
EXE_INC = \ -I$(LIB_SRC)/lduSolvers/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ -llduSolvers \ -lfiniteVolume As additional information this is being made in OF2106 Last edited by Shibi; February 9, 2022 at 05:23. |
February 9, 2022, 10:40 |
Rep Power: 6 |
February 9, 2022, 18:33 |
#6 | |
Mark Olesen
Rep Power: 40 |
I re-read your original question. You want to somehow get volume information from the lduMesh it seems? Not sure if I've properly understood what you are trying to do. In which file (please include the path) are you attempting to hack this in? |
February 9, 2022, 18:43 |
Rep Power: 6 |
Yes. I want to get volume information from e.g., the PCG solver. the above code seems to work, although I do not know if there is a more straightforward way of doing this.
February 14, 2022, 08:08 |
Rep Power: 6 |
Is the approach with dynamic_cast the best approach? Or is there something better?
February 14, 2022, 08:16 |
#9 | |
Rep Power: 6 |
To make this work I have to change: Code:
const fvMesh* myMesh = dynamic_cast<const fvMesh*>(&matrix().mesh()); to Code:
const fvMesh& myMesh = dynamic_cast<const fvMesh&>(matrix().mesh()); |
February 16, 2022, 14:13 |
#10 |
Mark Olesen
Rep Power: 40 |
I would normally write it like this:
const auto* meshPtr = isA<fvMesh>(matrix().mesh()); if (!meshPtr) FatalErrorInFunction .... const auto& myMesh = *meshPtr; |
February 16, 2022, 16:09 |
#11 | |
Rep Power: 6 |
Thanks for the input. It is shorter but on the background it should do the same thing: since the isA<fvMesh> function will do the casting. Code:
template<class TargetType, class Type> inline const TargetType* isA(const Type& t) { const Type* p = &t; return dynamic_cast<const TargetType*>(p); } but I will adopt it and thank you for the conversion check. |
February 17, 2022, 13:48 |
#12 | |
Mark Olesen
Rep Power: 40 |
Yes it is exactly the same under the hood, but saves other places in OpenFOAM where we previously had a check with isA<..> followed by a refCast<...> : not really any point performing the dynamic cast twice. The other important reason for that particular design pattern is that if you have a dynamic_cast<Type*>(...) it will return a nullptr if the casting fails, but if you use dynamic_cast<Type&>(...) it will throw a bad cast exception if the casting fails. So much easier to use the pointer version and not deal with try/catch things. |
March 10, 2022, 13:59 |
#13 |
Rep Power: 6 |
One further question, if possible.
Can I create a variable as: Code:
const fvMesh& meshRef_; Code:
meshRef_(initMeshRef()) Code:
const Foam::fvMesh& Foam::myClass::initMeshRef() const { const auto* meshPtr = isA<fvMesh>(matrix().mesh()); if (!meshPtr) { FatalErrorInFunction << "Some Error message" << nl << exit(FatalError); } return *meshPtr; } Sorry if this is too basic... |
March 10, 2022, 14:19 |
#14 |
Mark Olesen
Rep Power: 40 |
No problem and not necessarily bad style to have a const or non-const reference as a member variable. However you most certainly cannot easily or reliably do what you have written. Should either use a static method or a file-scope local function that take the matrix as a parameter and return the reference.
Take a look at this code chunk and work your way upwards to see how it's done. https://develop.openfoam.com/Develop...rDriver.C#L139 EDIT: if you need to, please check stackoverflow, google whatever. Try a small test class where you attempt to instantiate a member variable within the declaration of the constructor by calling a member function as part of that process (ie, what you've essentially scoped out here). See how successful you are. Try with clang as well to make sure that you are not relying on any special gcc "magic" to somehow save you. If you succeed or fail, please report back. Learning by doing is the only way to convince yourself here. Last edited by olesen; March 11, 2022 at 08:48. |
March 10, 2022, 15:27 |
#15 | |
Rep Power: 6 |
Edit: I don't know how to use clang (is it possible to do wmake $someFlag clang?. Will it work if I compiled OF with gcc?), but the function appears to work fine. I guess that since the mesh object is unique and derived from the lduMesh that is being used to cast, there should not be a problem. Last edited by Shibi; March 13, 2022 at 07:28. |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
volScalarField for cell volumes and face surfaces | AlmostSurelyRob | OpenFOAM | 2 | December 13, 2010 05:24 |
SVN 1226 - Possible bug with cell centres and volumes | philippose | OpenFOAM Bugs | 2 | June 5, 2009 13:19 |
