February 21, 2022, 12:01 |
Restart Simulation while running - fvc::grad(p) incorrect
Max
Rep Power: 4 |
Hey,
I have coded a modified version of icoFoam with another equation. Now I would like to restart the calculation after specific time meaning I would like to reset U and p to initial Values of time 0 (sounds confusing but is required because my implemented equation lead to a huge change in local U field... thus using the actual flow field lead to a divergence... thatīs why I would like to start from scratch there). I tried to do this by resetting phi, U and p field to initial values (which actually works) in each time step meaning I should get the same result on each step. But that doesnīt work. Hence I tried to figure out the line which destroys my simulation (printing phi, U and p after several lines of code). I found out that the mistake is done with " fvc::grad(p) " which is not calculated correctly. Now my Question: What exactly happens with fvc::grad(p)? Is there anything I need to reset to let it calculate correctly? For time step 1 it is zero in the internal field (defined by my init p field which is 0 at the whole mesh). At the second time step the gradient is not zero for each cell (but p is same as initial step). Thanks. Last edited by Maxxxx; February 22, 2022 at 06:10. |
Simulation getting crashed after running for 26 hours on HPC cluster | shivamswarnakar72 | OpenFOAM Running, Solving & CFD | 4 | August 23, 2020 00:11 |
Slow Running Simulation | rsoni451 | CONVERGE | 10 | September 15, 2017 09:20 |
Help running SST k-omega Stress-Blended Eddy Simulation | DA6righthand | FLUENT | 0 | July 15, 2017 10:44 |
Restart in time-accurate simulation | Arad | SU2 | 1 | May 25, 2016 08:08 |
OF-2.3.x: interPhaseChange(DyM)Foam: simulation restart leads to non-physical fields | A_Pete | OpenFOAM Bugs | 0 | August 12, 2015 09:16 |
