Get cell volumes from lduSolver
Old   February 8, 2022, 12:59
Default Get cell volumes from lduSolver
Shibi is on a distinguished road
Hello to all,
I would like to know if there is a way to retrieve the a reference to the scalarField storing the cell volume of the mesh from an ldusolver.
We could call the reference to the objectRegistry with:
const objectRegistry& a =  matrix().mesh().thisDb();
And possibly get the cell volumes with the cellVolumes() function from the primitiveMesh.
But I am getting the error:
error: invalid use of incomplete type ‘const class Foam::objectRegistry’
Would appreciate the help.
Shibi is offline   Reply With Quote
Old   February 9, 2022, 03:22
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The error means that objectRegistry was forward declared but not known completely in your code context.
Add an #include "objectRegistry.H" in your file.
Nonetheless not sure why you want to get at cell volumes in such a roundabout manner - they are directly available from the mesh - don't have to lookup from the registry.
olesen is offline   Reply With Quote
Old   February 9, 2022, 04:18
Thanks for the reply.
How so?
Inside the LDU solver, how can you get access to mesh volume?
Something like:
const fvMesh* myMesh = dynamic_cast<const fvMesh*>(&matrix().mesh());
 const scalarField& V = myMesh->V();
For the above code to work, you have to:
#include "fvMesh.H"
#include "volMesh.H"
and add to Make/options
EXE_INC = \
    -I$(LIB_SRC)/lduSolvers/lnInclude  \
    -I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = \
    -llduSolvers \
    -lfiniteVolume
Or something else?
As additional information this is being made in OF2106
Old   February 9, 2022, 06:44
Domenico Lahaye
dlahaye is on a distinguished road
Replace
by
const scalarField& V = myMesh.V();
dlahaye is offline   Reply With Quote
Old   February 9, 2022, 10:40
Originally Posted by dlahaye View Post
Replace
by
Not possible:
error: request for member ‘V’ in ‘myMesh’, which is of pointer type ‘const Foam::fvMesh*’ (maybe you meant to use ‘->’ ?)
   137 |     const scalarField& V = myMesh.V()
Old   February 9, 2022, 18:33
Mark Olesen
Originally Posted by Shibi View Post
Not possible:
I re-read your original question. You want to somehow get volume information from the lduMesh it seems? Not sure if I've properly understood what you are trying to do. In which file (please include the path) are you attempting to hack this in?
Old   February 9, 2022, 18:43
Yes. I want to get volume information from e.g., the PCG solver. the above code seems to work, although I do not know if there is a more straightforward way of doing this.
Old   February 14, 2022, 08:08
Is the approach with dynamic_cast the best approach? Or is there something better?
Old   February 14, 2022, 08:16
Replace
by
To make this work I have to change:
to
const fvMesh& myMesh = dynamic_cast<const fvMesh&>(matrix().mesh());
Old   February 16, 2022, 14:13
Mark Olesen
I would normally write it like this:
const auto* meshPtr = isA<fvMesh>(matrix().mesh());
if (!meshPtr) FatalErrorInFunction ....
const auto& myMesh = *meshPtr;
Old   February 16, 2022, 16:09
Hello Mr. Olesen.
Thanks for the input. It is shorter but on the background it should do the same thing: since the isA<fvMesh> function will do the casting.
template<class TargetType, class Type>
inline const TargetType* isA(const Type& t)
    const Type* p = &t;
    return dynamic_cast<const TargetType*>(p);
but I will adopt it and thank you for the conversion check.
Old   February 17, 2022, 13:48
Mark Olesen
Hello Mr. Olesen.
Yes it is exactly the same under the hood, but saves other places in OpenFOAM where we previously had a check with isA<..> followed by a refCast<...> : not really any point performing the dynamic cast twice.
The other important reason for that particular design pattern is that if you have a dynamic_cast<Type*>(...) it will return a nullptr if the casting fails, but if you use dynamic_cast<Type&>(...) it will throw a bad cast exception if the casting fails. So much easier to use the pointer version and not deal with try/catch things.
Old   March 10, 2022, 13:59
One further question, if possible.
Can I create a variable as:
const fvMesh& meshRef_;
And initialize it in the constructor with a function as:
meshRef_(initMeshRef())
const Foam::fvMesh& Foam::myClass::initMeshRef() const
    if (!meshPtr)
            << "Some Error message" << nl
            << exit(FatalError);
    return *meshPtr;
Is this good practice? Or should I not define a reference as a class attribute ?
Sorry if this is too basic...
Old   March 10, 2022, 14:19
Mark Olesen
No problem and not necessarily bad style to have a const or non-const reference as a member variable. However you most certainly cannot easily or reliably do what you have written. Should either use a static method or a file-scope local function that take the matrix as a parameter and return the reference.
Take a look at this code chunk and work your way upwards to see how it's done.
https://develop.openfoam.com/Develop...rDriver.C#L139
EDIT: if you need to, please check stackoverflow, google whatever. Try a small test class where you attempt to instantiate a member variable within the declaration of the constructor by calling a member function as part of that process (ie, what you've essentially scoped out here). See how successful you are. Try with clang as well to make sure that you are not relying on any special gcc "magic" to somehow save you. If you succeed or fail, please report back. Learning by doing is the only way to convince yourself here.
Old   March 10, 2022, 15:27
I did not quite understand this portion. This is to be placed inside a custom lduSolver (e.g., PBICGStab) so I should have the lduMesh reference to cast from the lduMatrix::solver.
Edit: I don't know how to use clang (is it possible to do wmake $someFlag clang?. Will it work if I compiled OF with gcc?), but the function appears to work fine. I guess that since the mesh object is unique and derived from the lduMesh that is being used to cast, there should not be a problem.
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 04:27
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
volScalarField for cell volumes and face surfaces AlmostSurelyRob OpenFOAM 2 December 13, 2010 05:24
SVN 1226 - Possible bug with cell centres and volumes philippose OpenFOAM Bugs 2 June 5, 2009 13:19
