Rotating heat sources - fixed mesh
Old   March 15, 2022, 06:26
Default Rotating heat sources - fixed mesh
Mohammad Reza
Bana is on a distinguished road
Hello All,
In my OpenFOAM simulation I am having a ring which the bottom and top regions of it are being meshed with a high resolution (attached image) since they are close to heat generation zones.
This ring should be a rotating one but we are making it fixed and let the other mating parts move. Also we need that the high resolution meshes always be at the top and the bottom.
Therefore the heat conducts to the two zones and need to rotate around the axis.
Can anyone suggest a method to somehow implement this? (the heat should be moving around the axis but the mesh not.)
Thank you in advance.
Bana is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Convective term in heat equation for rotating solids vabishek OpenFOAM Programming & Development 8 June 24, 2020 11:10
Rotating Mesh - Mesh Overlap/Discontinuity At Boundary Interface sai95kamal FLUENT 1 June 15, 2020 08:58
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
