Number of particles inside Cell
Old   February 5, 2022, 14:47
Default Number of particles inside Cell
Jairo A. Gutiérrez S
jairoandres is on a distinguished road
Dear all
I am working on a solution for OpenFOAM issue #2289 (https://develop.openfoam.com/Develop.../-/issues/2289), which affects both versions of OpenFOAM. The bug occurs when a particle-containing cell of level > 1, belonging to a wall boundary is unrefined.
One approach would be protecting the boundary-cells from unrefinement, which is discussed here: dynamicRefineFvMesh - Protect cells from refinement (boundary). However, this approach is not convenient as it blocks refinement in wall cells, which very often need to be refined.
The other option would be protecting from refinement cell containing particles. My idea is modifying the dynamicRefineFvMesh file, including something like:
forAll(cells(), celli)
const cell& nParcels = cells()[celli];
if (nParcels.parcelNumberinCell > 0)
protectedCell_.set(celli);
I am aware that there is no such thing as "parcelNumberinCell". What would be the best approach?
I am aware that p.cell() would return the cell number containing the parcel, but then it would require a loop through all parcels. This would be the same for cellOccupancy, right?
Any ideas?
Best regard
J.A. Gutiérrez
jairoandres is offline   Reply With Quote
Old   February 16, 2022, 04:42
Josh Williams
joshwilliams is on a distinguished road
Your point about cellOccupancy requiring a loop over all particles is incorrect, if I have understood your task correctly. You can simply do `cellOccupancy.size()', thus eliminating the need to loop over all particles. Here is a minimum example based on a time I have done something similar for cells containing no particles:
const polyMesh& pmesh = this->owner().mesh();
List<DynamicList<typename CloudType::parcelType*>>& cellOccupancy =
    this->owner().cellOccupancy();
// check all cells containing particles
forAll(pmesh.cells(), celli)
    if ( cellOccupancy[celli].size() == 0 )
        // do something
    else
        // do something else
Best,
Josh
joshwilliams is offline   Reply With Quote
Old   February 21, 2022, 08:48
Thank you Josh.. I am going to test it this week and I will let you know what happens.
Jairo.
Old   March 8, 2022, 09:59
Josh Williams
Any luck, Jairo?
Old   March 18, 2022, 17:14
Hi Josh, no I have not had any luck yet. I think my OpenFOAM C++ skills are lacking for this task, please correct me if I am wrong.
I suppose the modification must be included in the dynamicRefineFvMesh, as the protected cells (particle-containing) must be evaluated each time the mesh refinement / unrefinement is going to occur. I added something like this:
List<DynamicList<typename CloudType::parcelType*>>& cellOccupancy = this->owner().cellOccupancy();
    if ( cellOccupancy[celli].size() > 0 )
However, as far as I understand, the List<DynamicList<typename CloudType returns a list for each parcel and I don't think it can be called from dynamicRefineFvMesh. The compiling error is the following:
dynamicRefineFvMesh/dynamicRefineFvMesh.C: In member function ‘virtual bool Foam::dynamicRefineFvMesh::init(bool)’:
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1174:46: error: ‘const labelUList {aka const class Foam::UList<int>}’ has no member named ‘mesh’; did you mean ‘test’?
                                              test
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1175:49: error: template argument 1 is invalid
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1175:53: error: ‘cellOccupancy’ was not declared in this scope
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1176:19: error: ‘const labelUList {aka const class Foam::UList<int>}’ has no member named ‘cellOccupancy’
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1176:33: error: template argument 1 is invalid
I've have included the intermediate library to "#include "kinematicCloud.H", where cellOccupancy is defined, but that specific error still persists.
Any help is completely welcomed
Old   March 19, 2022, 08:51
Rishikesh
mrishi is on a distinguished road
It appears you are using 'this' from within the dynamicFvMesh file, but trying to access cloud members? Using 'this' will only work from within the cloud functions.
Are you able to access the mesh using something like
const polyMesh& mesh = cloud.pMesh();
mrishi is offline   Reply With Quote
Old   March 19, 2022, 18:10
Thank you mrishi, cloud was not declared but I added #include "cloud.H" at the start and the error stopped appearing. Still, pMesh, cellOccupancy are still undefined. What is weird to me(or beyond my knowledge) is that pMesh is supposed to be defined in cloud.H.
 dynamicRefineFvMesh/dynamicRefineFvMesh.C:1176:36: error: expected primary-expression before ‘.’ token
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1178:49: error: template argument 1 is invalid
 List<DynamicList<typename CloudType::parcelType*>>& cellOccupancy = cloud.pMesh().cellOccupancy();
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1178:53: error: ‘cellOccupancy’ was not declared in this scope
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1178:97: error: template argument 1 is invalid
dynamicRefineFvMesh/dynamicRefineFvMesh.C:1181:8: error: ‘pMesh’ was not declared in this scope
 forAll(pMesh.cells(), celli)
I have attached the dynamicRefineFvMesh file I am using (OF-2012) if you wish to take a look into it. Thanks!. Solving this issue should (in theory) fix a serious bug of openfoam when using AMR with particles.
Here is the attached file:
All the modifications are commented as: // JAG
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 07:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
