Which transformPoints() function is called when the mesh is rotating?
Old   April 5, 2022, 07:11
Question Which transformPoints() function is called when the mesh is rotating?
dzs
dntjudme is on a distinguished road
Hi foamers, this transformPoints() function is called when you are simulating for a rotating mesh case, which is the simulation I'm doing now.
My question initiated from the source code: solidBodyMotionSolver.C, in member function curPoints() at line 157. (Find it via link 1).
You may easily find that there are 2 transformPoints() functions are used, one is for mesh is not rotating, and another is used when mesh is rotating.
So my question is which transformPoints() function, defined in transformField.C at line 97 and 109, is used when mesh is not rotating (/and rotating)? (Find it via link 2).
link 1:https://cpp.openfoam.org/v7/solidBod...8C_source.html
link 2:https://cpp.openfoam.org/v7/transfor...ce.html#l00070
Thanks in helping!
zs
dntjudme is offline   Reply With Quote
dynamic mesh;
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
