Does order of instructions in make/options matters?
Old   April 11, 2022, 05:48
Default Does order of instructions in make/options matters?
Bhimesh Jetty
BJ_23 is on a distinguished road
Hello Foamers,
I have a basic question regarding how -L$(FOAM_USER_LIBBIN) in make/options works. I herewith attach an example for make/options:
EXE_INC = \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(WM_PROJECT_USER_DIR)/src/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lcompressibleTransportModels \
    -lfluidThermophysicalModels \
    -lspecie \
    -ltwoPhaseMixture \
    -linterfaceProperties \
    -lfiniteVolume
With the above instructions, I would like to create a shared object named libtwoPhaseMixtureThermo.so in user/platforms/lib. For this compilation, I need to reference libfluidThermophysicalModels.so which is also located in user/platforms/lib. Now the question is how does L$(FOAM_USER_LIBBIN) picks libfluidThermophysicalModels.so from user/platforms/lib as it is defined after -lcompressibleTransportModels in my order of instructions?
Does L$(FOAM_USER_LIBBIN) first picks all available shared objects listed in the make/options from user/platforms/lib and then goes to opt/platforms/lib?
BJ_23 is offline   Reply With Quote
Old   April 11, 2022, 20:23
brucethemuce is on a distinguished road
The order should not matter, compile and see what errors you get
brucethemuce is offline   Reply With Quote
Order of #include matters for QtCreator gcengineer OpenFOAM Programming & Development 1 November 12, 2019 21:52
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
Unstable flow simpleFoam 2nd order Valle OpenFOAM 0 August 26, 2009 08:12
SECOND ORDER DON'T CONVERGE, WHY?????????? naus FLUENT 10 March 13, 2006 07:21
1st order temporal & 2nd order spatial Prateep Chatterjee FLUENT 0 January 19, 2003 00:31
