Compiling kOmegaSST in Openfoam 9
Old   May 10, 2022, 09:24
Default Compiling kOmegaSST in Openfoam 9
Alex
_helix22_ is on a distinguished road
Hi everyone,
I am currently working on modifying the kOmegaSST Turbulence model for a research project. I previously worked in Openfoam V2112 (so the ESI version) using
this tutorial and it worked nicely. However, because I need some features of Openfoam 9 I have to recompile the model for OF9. Due to significant differences between these versions, I decided to start with a clean slate, and, as an initial step, just copy and rename the kOmegaSST model (as suggested in most Tutorials). But here I already get lost in includes and dependencies, as a lot of files have been renamed since OF 6... My primary problem is setting up the Make folder and finding out which file to make... Does anyone here have experience with compiling turbulence models in OF9 or maybe knows of a tutorial which I was too stupid to find?
Thanks in advance,
All the best,
Alex
_helix22_ is offline   Reply With Quote
Old   May 10, 2022, 13:07
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
maybe I am wrong, but you can try.
1. Use $FOAM_SRC/src/ThermophysicalTransportModels/
instead of
$FOAM_SRC/TurbulenceModels/turbulenceModels
from your tutorial.
2. Run
wmake libso
from copy of
ThermophysicalTransportModels folder to generate libfile.
Here README of lib generation and usage in OpenFOAM
as example.
j-avdeev is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 03:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
