Add mesh refinement to solidDisplacementFoam solver |
May 10, 2022, 12:39 |
Avdeev Evgeniy
Rep Power: 21 |
Hi, foamers.
I am trying to make solidDisplacementFoam solver with adaptive mesh refinement support. Initially I use solidDisplacementFoam from OF v9 foundation branch. As was mentioned previously I just need to "add the dynamicFvMesh lib to the solver, derive the mesh creation out of that library" and do not forget to recalculate the fluxes for updated mesh. But I am stuck on "how to update fields for new mesh". Most of examples from OF distribution are about updating fluid fields (phi, U - correctPhi.H), but what should I do in case of solidDisplacementFoam solver? How should look updating of displacement D field? Any thoughts are appreciated. Thanks. |
mesh refinement |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 10:11 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
