Parallel Run Compatibility Issue of the Implementation to the Solver |
August 17, 2022, 03:15 |
Can Unsal
Rep Power: 6 |
Hello All,
I have created my solver by introducing some additional variables and methods to calculate them to the solver "interPhaseChangeFoam". The solver works fine and gives me the satisfying output. However, the way that i implemented my code is not suitable to run on parallel. So i decided to modify my calculation to create a post processing tool instead off making the calculation on run time. Here what i needed to do: 1) After reconstructing the case, i need to reach values of each cell (U, P_rgh etc.) 2) I need to use values which were calculated during runtime and calculate my new variable (for example at time step 0.0001 newVelo[cellI] = 2*U[cellI]) 3) I need my code loop through all the results, check some conditions and calculate my variables I am kindly asking you whether is there a code template that i can use that loops through the calculated results. Thanks in advance |
August 22, 2022, 15:48 |
Klaus
Rep Power: 22 |
I suggest to check the capabilities of paraFOAM i.e. ParaView which is the standard post processing application, maybe it offers the functionality you need.
OpenFOAM benchmarks on various hardware | eric | Hardware | 778 | April 23, 2024 16:56 |
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver | malicemethods | FLUENT | 3 | May 25, 2018 14:25 |
issue decomposepar for parallel run. | manuc | OpenFOAM Pre-Processing | 2 | June 13, 2016 02:39 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
SnappyHexMesh OF-1.6-ext crashes on a parallel run | norman1981 | OpenFOAM Bugs | 5 | December 7, 2011 12:48 |
