How to extract Differential Equations Matrix Coeff
Old   July 3, 2012, 07:13
Post How to extract Differential Equations Matrix Coeff
Samuel Rodriguez Bernabeu
srodrb is on a distinguished road
Hello Foamers!
I'm pretty new in OpenFoam world, but not in CFD. I've spent 3-4 months working with OP so I have the generals although my field are mathematics, not aerodynamics.
I'm working on differential equations systems acceleration using hybrid methods (CPU-GPU) for my thesis.
My question is:
How can I get an output of OP with the coefficients matrix (the matrix which OpenFoam solves later)?
Thank you.
PD: - I will publish the results and the source under GNU license.
- Sorry about my english
srodrb is offline   Reply With Quote
Old   July 6, 2012, 07:46
Steven van Haren
stevenvanharen is on a distinguished road
Did you look here?
src » finiteVolume » fvMatrices » fvMatrix
There are a lot of options for output I think.
stevenvanharen is offline   Reply With Quote
Old   July 31, 2012, 06:22
Thanks for your help.
I'm still trying to find the way. This link helped me, so perhaps it could be useful for someone.
http://188.40.164.115/wordpress/?p=39#comment-44
Old   August 1, 2012, 15:27
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Samuel, if you want to extract these values at debugging time and many other debug hacks you have gdbOF
http://openfoamwiki.net/index.php/Contrib_gdbOF
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   October 30, 2012, 03:14
Default Coeff. Matrix. It's correct?
Hello again!
I've been working with other stuff for some time so I've come back with OpenFOAM.
I've write out the matrix coefficients in a file for the cavity (2D) tutorial solved with icoFoam.
Note that coeff. [1][1] is on the left bottom
My question is, it is correct the addressing? Are there additional terms out of diagonals? (Wiki' figure is different from mine but I'm not sure if that would be extendible for 2D cases or only for 3D ones... )
I'm reading some post of addressing... Thank you in advance.
Old   August 12, 2022, 09:59
shizuka is on a distinguished road
I see it's an old post, all the links are not available after 10 years...
is there anyone happen to have some new links to this question? Thank you in advance.
shizuka is offline   Reply With Quote
Old   August 12, 2022, 12:19
Domenico Lahaye
dlahaye is on a distinguished road
This link https://openfoamwiki.net/index.php/Contrib_gdbOF
still works. Let us know how it goes. Good luck.
dlahaye is offline   Reply With Quote
Old   August 13, 2022, 04:51
Hi dlahaye, you are right, i overlooked this link on #4, thank you!
matrix, openfoam
Force can not converge colopolo CFX 13 October 4, 2011 22:03
differential equations cosine CFX 1 May 31, 2010 07:22
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
Error: Could'nt allocate fine level coeff matrix Khan FLUENT 1 July 7, 2006 01:44
free " ordinary differential equations solver" ztdep Main CFD Forum 2 March 21, 2006 01:58
