Pesky "Warnings" with custom boundary condition
Old   October 19, 2022, 14:33
Default Pesky "Warnings" with custom boundary condition
Charlie L
cosmicCharlie is on a distinguished road
Using OF10, ubuntu 22.04. I implemented a modified dynamic contact angle model, based on the standard OF model dynamicAlphaContactAngle. The modified model myDynamicContactAngle compiles & runs. wmake installed it in $FOAM_USER_LIBBIN and I included in controlDict as:
libs ("libmyDynamicContactAngle.so" "libOpenFOAM.so");
As long as the libs command is active in controlDict I get the following warning when I run every OF application (blockMesh, decomposePar, paraFoam etc.):
--> FOAM Warning :
From function void* Foam::dlOpen(const Foam::fileName&, bool)
in file POSIX.C at line 1247
dlopen error : /opt/openfoam10/platforms/linux64GccDPInt32Opt/lib/libtwoPhaseMixture.so: undefined symbol: _ZN4Foam18physicalProperties8typeNameE
--> FOAM Warning :
From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 106
could not load "libmyDynamicContactAngle.so"
I've been ignoring the warning, but I'd like to understand and correct (if possible) whatever is going wrong. I examined line 1247 in POSIX.C and line 106 in dlLibraryTable.C but all I found were the error message output statements. No trail of bread crumbs back to the problem.
When I created the new model I copied dynamicAlpha etc. .C and .H to my user src directory, and I modified and/or added the necessary includes, and did the same for wmake. Here are the wmake files:
options:
EXE_INC = \
-I$(LIB_SRC)/twoPhaseModels/twoPhaseProperties/lnInclude \
-I$(LIB_SRC)/twoPhaseModels/twoPhaseMixture/lnInclude \
-I$(LIB_SRC)/twoPhaseModels/interfaceProperties/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
-ltwoPhaseProperties \
-ltwoPhaseMixture \
-linterfaceProperties \
-lfiniteVolume
files:
myDynamicContactAngle/myDynamicContactAngleFvPatchScalarField.C
LIB = $(FOAM_USER_LIBBIN)/libmyDynamicContactAngle
Note in options I had to include /twoPhaseModels/twoPhaseProperties to get the code to compile, this is not used in OF's dynamicAlpha etc.
Any suggestions?
Thanks, Charlie
cosmicCharlie is offline   Reply With Quote
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
