How to compile new function object in openfoam? |
January 13, 2023, 01:02 |
Farzad Faraji
Rep Power: 7 |
Hello all
I want to change one of the functionObjects so I copy it and make a new funtionObject, and now I want to compile it so I can use it in the controlDict. How should I compile new function object in openfoam? Thanks, Farzad |
January 13, 2023, 04:56 |
Rep Power: 8 |
You should run:
wmake libso
"When in doubt, use brute force." -- Ken Thompson |
January 13, 2023, 05:26 |
Farzad Faraji
Rep Power: 7 |
January 13, 2023, 06:41 |
Rep Power: 8 |
To rename the function object, modify the file:
Make/files
compile, functionobject, openfoam |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
