Using PETSc with cyclicAMI in OpenFOAM (2206) - not supported? |
January 6, 2023, 03:14 |
TWB
Rep Power: 19 |
I'm trying to use PETSc with cyclicAMI in OpenFOAM (2206). However, I got the error msg: Code:
solvers/petscSolver.C at line 671. [147] FOAM parallel run exiting [147] [46] [158] From void Foam::petscSolver::buildMat(_p_Mat*&, Foam::List<int>&, PetscInt&) const [158] in file solvers/petscSolver.C at line 671. [158] FOAM parallel run exiting [158] [30] cyclicAMI is not supported [30] [30] [30] From void Foam::petscSolver::buildMat(_p_Mat*&, Foam::List<int>&, PetscInt&) const Code:
solver petsc; petsc { options { ksp_type cg; ksp_cg_single_reduction true; ksp_norm_type none; // With or without hypre //#if 0 mat_type aij; pc_type hypre; pc_hypre_type boomeramg; pc_hypre_boomeramg_max_iter "1"; pc_hypre_boomeramg_strong_threshold "0.25"; pc_hypre_boomeramg_grid_sweeps_up "1"; pc_hypre_boomeramg_grid_sweeps_down "1"; pc_hypre_boomeramg_agg_nl "1"; pc_hypre_boomeramg_agg_num_paths "1"; pc_hypre_boomeramg_max_levels "25"; pc_hypre_boomeramg_coarsen_type HMIS; pc_hypre_boomeramg_interp_type ext+i; pc_hypre_boomeramg_P_max "1"; pc_hypre_boomeramg_truncfactor "0.3"; |
January 27, 2023, 06:08 |
Rep Power: 8 |
Checking the source code of the petscFoam module confirms that currently, it doesn't support cyclicAMI
"When in doubt, use brute force." -- Ken Thompson |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
