XiFoam dependance on initial conditions
Old   January 20, 2023, 08:57
Default XiFoam dependance on initial conditions
Sarah
Sarah13 is on a distinguished road
Hi All!
I am using XiFoam solver to model flame propagation inside a rectangular cross-section, but I have observed that my solution depends a lot on the initial conditions of the case, like: mesh size, max Courant number, time step, initial values of k (turbulent kinetic energy). I am able to obtain good results for one set of conditions but as soon as I change the mesh (for grid independence study) my results change.
Has anyone else faced any similar kind of problem with XiFoam or any other solver in OpenFOAM?
If I can get any help regarding this situation, as how to proceed for grid independence study, I would be extremely grateful. By the way, I am using adaptive time step for the same.
Thanks a lot in advance!
Sarah13 is offline   Reply With Quote
Old   February 1, 2023, 07:16
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Welcome to CFD. It all depends. If we change, e.g., the mesh or the numerical schemes, you will see the influence. Its normal but you should be aware which set-up you use, which parameter influences your stuff and so on.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Help sought on axial compressor simulation jyotir OpenFOAM Running, Solving & CFD 0 November 17, 2021 10:49
Compressible flows with larger Courant numbers Tobi OpenFOAM Running, Solving & CFD 5 February 26, 2021 15:20
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
