Compilation error when using boost Bessel function in OpenFOAM
Old   April 14, 2023, 10:54
Default Compilation error when using boost Bessel function in OpenFOAM
streamLiner is on a distinguished road
I am trying to make a custom solver based on pimpleFoam, which includes a Bessel function in an equation which I added in the PIMPLE-loop. In the beginning of the solver, I have an include-statement which I believe I need to use the Bessel-function from boost:
#include <boost/math/special_functions/bessel.hpp>
However, I get a compilation error when I run "wmake" (here quoting selected parts of a long error message):
usr/include/boost/math/special_functions/detail/bernoulli_details.hpp: In function ‘std::size_t boost::math::detail::find_bernoulli_overflow_limit(const false_type&)’:
/usr/include/boost/math/special_functions/detail/bernoulli_details.hpp:104:63: error: call of overloaded ‘sqrt(double)’ is ambiguous
  104 |    double result = boost::math::tools::toms748_solve(fun, sqrt(double(t)), double(t), tol, max_iter).first / 2;
/opt/openfoam10/src/OpenFOAM/lnInclude/dimensionedScalar.H:65:19: note: candidate: ‘Foam::dimensionedScalar Foam::sqrt(const dimensionedScalar&)’
   65 | dimensionedScalar sqrt(const dimensionedScalar&);
make: *** [/opt/openfoam10/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/cEHDfoam.o] Error 1
The solver compiles (and simulates) fine if I exclude the bessel-related "#include" statement and replace the bessel function with something else. Thus the error seems to be caused by the include-statement itself.
What could I do to solve this problem? If I include other boost library functions, for example "elliptic integral" from the "special functions" directory, then it compiles without error. So the error seems localized to bessel. And it seems the compiler is complaining about "sqrt( )" somehow (which I didn't type in or add anywhere, must come from boost).
Very strange! I'm thankful for any tips/suggestions you may have.
streamLiner is offline   Reply With Quote
bessel, boost, compilation, error, library
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
