Regarding the energy equation(Internal energy equation) in the sonicFoam solver.
Like Tree2Likes
  • 1 Post By dlahaye
  • 1 Post By dlahaye
Prev Previous Post   Next Post Next
Old   May 15, 2023, 22:26
Post Regarding the energy equation(Internal energy equation) in the sonicFoam solver.
applekiller is on a distinguished road
Hello,every Foamer, This is my first time posting a question in this community, and I am looking forward to everyone's answers.
I have a question about solving the energy equation (internal energy equation) in sonicFoam.
In EEqn.H of sonicFoam(I added some comments )
HTML Code:
    fvScalarMatrix EEqn
        fvm::ddt(rho, e) + fvm::div(phi, e)
      + fvc::ddt(rho, K) + fvc::div(phi, K)
      + fvc::div(fvc::absolute(phi/fvc::interpolate(rho), U), p, "div(phiv,p)") // fvc::absolute does nothing for static mesh
      - fvm::laplacian(turbulence->alphaEff(), e)   // turbulence->alphaEff() returns lambda/c_p or lambda/c_v depending on the solution variable e or h
        fvOptions(rho, e)
The equation represented by this code seems to be
\frac{\partial \rho e}{\partial t} + \frac{1}{2}\frac{\partial \rho\pmb{u}^2}{\partial t} + \nabla\cdot(\rho e\pmb{u})+\frac{1}{2}\nabla\cdot(\rho \pmb{u}\pmb{u^2}) + \nabla\cdot(\pmb{u}p) + \nabla\cdot\pmb{q} = 0
In above equation
\pmb{u}^2 = \pmb{u}\cdot\pmb{u}
\pmb{q} = -\lambda\nabla T
e = C_v T
But if the total energy equation
\frac{\partial \rho E}{\partial t} + \nabla\cdot(\pmb{u}(\rho E+p)) - \nabla\cdot(\pmb{\tau}\cdot\pmb{u}) + \nabla\cdot \pmb{q} = 0
is expanded into the form of an internal energy equation, then the internal energy equation is like this.
\frac{\partial \rho e}{\partial t} + \frac{1}{2}\frac{\partial \rho\pmb{u}^2}{\partial t} + \nabla\cdot(\rho e\pmb{u})+\frac{1}{2}\nabla\cdot(\rho \pmb{u}\pmb{u^2}) + \nabla\cdot(\pmb{u}p) - \underline{\nabla\cdot(\pmb{\tau}\cdot\pmb{u})}+ \nabla\cdot\pmb{q} = 0
By comparing the internal energy equation represented in the code in OpenFOAM with the internal energy equation we derived, it can be seen that the internal energy equation solved in OpenFOAM lacks the viscous term-\nabla\cdot(\pmb{\tau\cdot\pmb{u}}).
So my question is,
1) Why does OpenFOAM omit the viscous term in solving the internal energy equation?
2) Does this handling have a significant impact on the results? (After all, the viscous term is missing from the internal energy equation)
I am looking forward to everyone's answer to this question and best wishes for everyone.
applekiller is offline   Reply With Quote
How is strength value used in the Energy Equation of XiFoam solver? Manideep304 OpenFOAM Running, Solving & CFD 3 August 30, 2022 02:20
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 06:33
modify a solver to account for energy equation. Yanci OpenFOAM Running, Solving & CFD 0 November 11, 2014 09:23
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
