how to add a new k-e model for twophaseeulerfoam? |
February 11, 2020, 12:40 |
Hi guys,
I had question that it is possible add a new turbulence model in Turbulence->incompressible->turbulentTransportModels.C (#include "mykEpsilon.H" makeRASModel(mykEpsilon) However, I cannot find one file in phasecompressibleturbulencemodel. So How can I add a new k-epsilon model based on k-epsilon for twophaseeulerfoam? I added one code in the twophaseeulerfoam solver->phasecompressibleturbulencemodels.C as following but I faild to use this model in the test case. makeTurbulenceModelTypes ( volScalarField, volScalarField, compressibleTurbulenceModel, PhaseCompressibleTurbulenceModel, ThermalDiffusivity, phaseModel ); makeBaseTurbulenceModel ( volScalarField, volScalarField, compressibleTurbulenceModel, PhaseCompressibleTurbulenceModel, ThermalDiffusivity, phaseModel ); #define makeLaminarModel(Type) \ makeTemplatedLaminarModel \ (phaseModelPhaseCompressibleTurbulenceModel, laminar, Type) #define makeRASModel(Type) \ makeTemplatedTurbulenceModel \ (phaseModelPhaseCompressibleTurbulenceModel, RAS, Type) #define makeLESModel(Type) \ makeTemplatedTurbulenceModel \ (phaseModelPhaseCompressibleTurbulenceModel, LES, Type) #include "Stokes.T.H" makeLaminarModel(Stokes); #include "kEpsilon.H" makeRASModel(kEpsilon); #include "mykEpsilon.H" makeRASModel(mykEpsilon); |
February 11, 2020, 12:54 |
Herpes Free Engineer
Rep Power: 12 |
didn't understand the question, but are you trying to find the following file?
src/phaseSystemModels/reactingEulerFoam/reactingTwoPhaseEulerFoam/twoPhaseCompressibleTurbulenceModels/phaseCompressibleTurbulenceModels.C
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 11, 2020, 13:16 |
#3 | |
My question is to add a new turbulence model for twophaseeulerfoam. |
February 11, 2020, 13:18 |
Rep Power: 12 |
I don't think you can add or you need to add a turbulence model into a solver.
Instead, forum dudes can try to help you out for the compilation problem.
February 11, 2020, 13:22 |
February 11, 2020, 15:22 |
Rep Power: 12 |
Yes, you should implement a new turbulence model. But this turbulence model is not going to be implemented into a solver. It is a separate entity from a solver. Once you implement a new turbulence model, you can mostly use it with any solvers.
Anyways, I think you are looking for on how to implement a new turbulence model. I think we should understand your question in this way. Could you please attach any error messages from the compilation attempt?
February 11, 2020, 15:26 |
Michael Alletto
Rep Power: 15 |
Do you know this blog http://hassankassem.me/posts/newturbulencemodel/. You can also use the coded fvoption functionality to add missing terms to existing turbulence models
February 12, 2020, 10:50 |
#8 | |
According to this thread, Adding New phaseCompressible Turbulence Model I cannot compile successfully. Do you have some suggests? |
February 12, 2020, 16:29 |
#9 |
Michael Alletto
Rep Power: 15 |
Can you post the errors you get
February 13, 2020, 03:07 |
#10 |
$ wmake wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file myphaseCompressibleTurbulenceModels.C could not open file ThermalDiffusivity.H for source file myphaseCompressibleTurbulenceModels.C could not open file EddyDiffusivity.H for source file myphaseCompressibleTurbulenceModels.C could not open file laminar.H for source file myphaseCompressibleTurbulenceModels.C could not open file RASModel.H for source file myphaseCompressibleTurbulenceModels.C could not open file LESModel.H for source file myphaseCompressibleTurbulenceModels.C $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath x86_64-w64-mingw32-g++) -std=c++11 -Dmingw_w64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DWIN64 -DLITTLE_ENDIAN -DWIN64 -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O2 -DNDEBUG -gdwarf -DNoRepository -ftemplate-depth-100 -D_FILE_OFFSET_BITS=64 -D_MODE_T_ -I/home/ofuser/blueCFD/OpenFOAM-5.x/applications/solvers/multiphase/twoPhaseEulerFoam/twoPhaseSystem/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/basic/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/specie/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/solidThermo/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/solidSpecie/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/finiteVolume/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/meshTools/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/applications/solvers/multiphase/twoPhaseEulerFoam/interfacialModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/incompressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/phaseCompressible/lnInclude @Make/mingw_w64GccDPInt32Opt/includeHeaderPaths -IlnInclude -I. -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OSspecific/MSwindows/lnInclude -c myphaseCompressibleTurbulenceModels.C -o J:/blueCFD-Core-2017/ofuser-of5/applications/solvers/mytwoPhaseEulerFoam4/phaseCompressibleTurbulenceModels/Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o myphaseCompressibleTurbulenceModels.C:32:10: fatal error: ThermalDiffusivity.H: No such file or directory #include "ThermalDiffusivity.H" ^~~~~~~~~~~~~~~~~~~~~~ compilation terminated. After I changed all header files as the original ones like #include "PhaseCompressibleTurbulenceModel.T.H" #include "phaseModel.H" #include "twoPhaseSystem.H" #include "addToRunTimeSelectionTable.H" #include "makeTurbulenceModel.H" #include "ThermalDiffusivity.T.H" #include "EddyDiffusivity.T.H" #include "laminarModel.H" #include "RASModel.T.H" #include "LESModel.T.H" The errors above were disappeared, however it failed again. $ wmake wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file myphaseCompressibleTurbulenceModels.C $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath x86_64-w64-mingw32-g++) -std=c++11 -Dmingw_w64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DWIN64 -DLITTLE_ENDIAN -DWIN64 -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O2 -DNDEBUG -gdwarf -DNoRepository -ftemplate-depth-100 -D_FILE_OFFSET_BITS=64 -D_MODE_T_ -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/finiteVolume/lnInclude -I../twoPhaseSystem/lnInclude -I../interfacialModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/basic/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/incompressible/transportModel -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/phaseCompressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/meshTools/lnInclude @Make/mingw_w64GccDPInt32Opt/includeHeaderPaths -IlnInclude -I. -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OSspecific/MSwindows/lnInclude -c myphaseCompressibleTurbulenceModels.C -o J:/blueCFD-Core-2017/ofuser-of5/applications/solvers/mytwoPhaseEulerFoam4/phaseCompressibleTurbulenceModels/Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath windres) Make/mingw_w64GccDPInt32Opt/version_of_build.rc Make/mingw_w64GccDPInt32Opt/version_of_build.o $(/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/scripts/makeReinterpretExePath x86_64-w64-mingw32-g++) -std=c++11 -Dmingw_w64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DWIN64 -DLITTLE_ENDIAN -DWIN64 -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O2 -DNDEBUG -gdwarf -DNoRepository -ftemplate-depth-100 -D_FILE_OFFSET_BITS=64 -D_MODE_T_ -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/finiteVolume/lnInclude -I../twoPhaseSystem/lnInclude -I../interfacialModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/thermophysicalModels/basic/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/transportModels/incompressible/transportModel -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/compressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/TurbulenceModels/phaseCompressible/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/meshTools/lnInclude @Make/mingw_w64GccDPInt32Opt/includeHeaderPaths -IlnInclude -I. -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OpenFOAM/lnInclude -I/home/ofuser/blueCFD/OpenFOAM-5.x/src/OSspecific/MSwindows/lnInclude -Wl,--output-def,/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib/mymixtureKEpsilon.def -Wl,--out-implib,/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib/mymixtureKEpsilon.a -Wl,--enable-auto-import -shared @Make/mingw_w64GccDPInt32Opt/objectList -L/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib \ -lOpenFOAM -L/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/MS-MPI-7.1 -lPstream -lcompressibleTransportModels -lfluidThermophysicalModels -lspecie -lturbulenceModels -lcompressibleTurbulenceModels -lincompressibleTransportModels -lcompressibleTwoPhaseSystem -lcompressibleEulerianInterfacialModels -lfiniteVolume -lfvOptions -lmeshTools -o /home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib/mymixtureKEpsilon.dll Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o: In function `Foam::RASModel<Foam::EddyDiffusivity<Foam::Therma lDiffusivity<Foam::PhaseCompressibleTurbulenceMode l<Foam:haseModel> > > >::adddictionaryConstructorToTable<Foam::RASModels ::mykEpsilon<Foam::EddyDiffusivity<Foam::ThermalDi ffusivity<Foam::PhaseCompressibleTurbulenceModel<F oam:haseModel> > > > >::~adddictionaryConstructorToTable()': J:/blueCFD-Core-2017/OpenFOAM-5.x/src/TurbulenceModels/turbulenceModels/RAS/RASModel/RASModel.T.H:111: undefined reference to `Foam::RASModel<Foam::EddyDiffusivity<Foam::Therma lDiffusivity<Foam::PhaseCompressibleTurbulenceMode l<Foam:haseModel> > > >::destroydictionaryConstructorTables()' Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o: In function `Foam::RASModel<Foam::EddyDiffusivity<Foam::Therma lDiffusivity<Foam::PhaseCompressibleTurbulenceMode l<Foam:haseModel> > > >::adddictionaryConstructorToTable<Foam::RASModels ::mykEpsilon<Foam::EddyDiffusivity<Foam::ThermalDi ffusivity<Foam::PhaseCompressibleTurbulenceModel<F oam:haseModel> > > > >::adddictionaryConstructorToTable(Foam::word const&)': J:/blueCFD-Core-2017/OpenFOAM-5.x/src/TurbulenceModels/turbulenceModels/RAS/RASModel/RASModel.T.H:111: undefined reference to `Foam::RASModel<Foam::EddyDiffusivity<Foam::Therma lDiffusivity<Foam::PhaseCompressibleTurbulenceMode l<Foam:haseModel> > > >::constructdictionaryConstructorTables()' Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o:myphaseCompr essibleTurbulenceModels.C.rdata$.refptr._ZN4Foam 8RASModelINS_15EddyDiffusivityINS_18ThermalDiffusi vityINS_32PhaseCompressibleTurbulenceModelINS_10ph aseModelEEEEEEEE30dictionaryConstructorTablePtr_E[.refptr._ZN4Foam8RASModelINS_15EddyDiffusivityINS_ 18ThermalDiffusivityINS_32PhaseCompressibleTurbule nceModelINS_10phaseModelEEEEEEEE30dictionaryConstr uctorTablePtr_E]+0x0): undefined reference to `Foam::RASModel<Foam::EddyDiffusivity<Foam::Therma lDiffusivity<Foam::PhaseCompressibleTurbulenceMode l<Foam:haseModel> > > >::dictionaryConstructorTablePtr_' Make/mingw_w64GccDPInt32Opt/myphaseCompressibleTurbulenceModels.o:myphaseCompr essibleTurbulenceModels.C.rdata$.refptr._ZN4Foam 8RASModelINS_15EddyDiffusivityINS_18ThermalDiffusi vityINS_32PhaseCompressibleTurbulenceModelINS_10ph aseModelEEEEEEEE8typeNameE[.refptr._ZN4Foam8RASModelINS_15EddyDiffusivityINS_ 18ThermalDiffusivityINS_32PhaseCompressibleTurbule nceModelINS_10phaseModelEEEEEEEE8typeNameE]+0x0): undefined reference to `Foam::RASModel<Foam::EddyDiffusivity<Foam::Therma lDiffusivity<Foam::PhaseCompressibleTurbulenceMode l<Foam:haseModel> > > >::typeName' collect2.exe: error: ld returned 1 exit status make: *** [/home/ofuser/blueCFD/OpenFOAM-5.x/wmake/makefiles/general:214: /home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib/mymixtureKEpsilon.dll] Error 1 |
February 14, 2020, 11:14 |
#11 |
Michael Alletto
Rep Power: 15 |
Hm something went wrong with a template parameter. But just from the information you provided it is difficult to judge what went wrong.
I suggest just to copy an existing model and rename it and try to compile it. If you sussed with this you step by step make the changes you require and compile it again after each change. If you're not able to compile it you exactly know where the error comes from |
February 14, 2020, 11:45 |
#12 | |
February 17, 2020, 05:39 |
#13 |
Michael Alletto
Rep Power: 15 |
no actually not but the principle should be the same. phase compressible models are essentially compressible turbulence models. If you look at PhaseCompressibleTurbulenceModel.H you will see it. I found this only looking a bit at the source code.
So did you try to compy a compressible kEpsilon equation rename it and try to include it in the file multiphaseCompressibleTurbulenceModels.C. mybe this link is usefull to understand the undifined reference error: https://latedev.wordpress.com/2014/0...ved-reference/ |
February 17, 2020, 05:52 |
#14 | |
Thanks a lot. I tried but I failed. Could you please help me to have a look my source code.. I put those files in the folder phasecompressibleturbulencemodel (twophaseeulerfoam). |
February 17, 2020, 06:21 |
#15 |
Michael Alletto
Rep Power: 15 |
your file myphaseCompressibleTurbulenceModels.C is not the same as the file
src/phaseSystemModels/reactingEulerFoam/reactingMultiphaseEulerFoam/multiphaseCompressibleTurbulenceModels/multiphaseCompressibleTurbulenceModels.C see below Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | www.openfoam.com \\/ M anipulation | ------------------------------------------------------------------------------- Copyright (C) 2014-2018 OpenFOAM Foundation ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "phaseCompressibleTurbulenceModel.H" #include "addToRunTimeSelectionTable.H" #include "makeTurbulenceModel.H" #include "laminarModel.H" #include "RASModel.H" #include "LESModel.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // makeTurbulenceModelTypes ( volScalarField, volScalarField, compressibleTurbulenceModel, PhaseCompressibleTurbulenceModel, ThermalDiffusivity, phaseModel ); makeBaseTurbulenceModel ( volScalarField, volScalarField, compressibleTurbulenceModel, PhaseCompressibleTurbulenceModel, ThermalDiffusivity, phaseModel ); #define makeLaminarModel(Type) \ makeTemplatedLaminarModel \ (phaseModelPhaseCompressibleTurbulenceModel, laminar, Type) #define makeRASModel(Type) \ makeTemplatedTurbulenceModel \ (phaseModelPhaseCompressibleTurbulenceModel, RAS, Type) #define makeLESModel(Type) \ makeTemplatedTurbulenceModel \ (phaseModelPhaseCompressibleTurbulenceModel, LES, Type) #include "Stokes.H" makeLaminarModel(Stokes); #include "kEpsilon.H" makeRASModel(kEpsilon); #include "kOmegaSST.H" makeRASModel(kOmegaSST); #include "Smagorinsky.H" makeLESModel(Smagorinsky); #include "kEqn.H" makeLESModel(kEqn); // ************************************************************************* // Use the above file to compile you code. This should work. And check the file Make/options there the information for the linker is provided. The undefined reference error is probably a linker error. It does not find some files or definition in some library. |
February 17, 2020, 08:06 |
#16 | |
And also these codes cannot be used in the latest version. #include "phaseCompressibleTurbulenceModel.H" #include "addToRunTimeSelectionTable.H" #include "makeTurbulenceModel.H" #include "laminarModel.H" #include "RASModel.H" #include "LESModel.H" It should be "phaseCompressibleTurbulenceModel.T.H" etc.. |
February 18, 2020, 04:53 |
#17 |
Michael Alletto
Rep Power: 15 |
I just modified the file multiphaseCompressibleTurbulenceModels.C (see blow) including the turbulencemodel mykEpsilon. It is just a copy of the existing kEpsilon model. I replaces obviously all string from kEpsilon to mykEpsilon. The compilation worked.
February 18, 2020, 05:36 |
#18 | |
June 24, 2023, 11:52 |
#19 |
Guilherme
Rep Power: 10 |
multiphase flow, turbulence models, twophaseeuelrfoam |
[IHFOAM] The IHFOAM Thread | Phicau | OpenFOAM Community Contributions | 392 | September 8, 2023 18:10 |
add a fuel cell model in ansys fluent 15 | msdkhl | FLUENT | 0 | June 15, 2016 09:14 |
Add Singhal model into interPhaseChangeFoam | zhouhoucun | OpenFOAM Running, Solving & CFD | 0 | April 28, 2015 04:32 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Add additional scalar to turbulence model | john_w | OpenFOAM | 1 | December 23, 2010 12:45 |
