How to get the current time within the controlDict? |
November 4, 2014, 13:53 |
duan
Rep Power: 12 |
I am trying to set different writeTimeInterval rather than a constant one during the runTime. for example: if (currentRunTime<t0) writeTimeInterval=value0; else writeTimeInterval=value1; Now I have problems on how to get current time within the controlDict. Here is my code: Code:
writeInterval #codeStream { code #{ /*// the sample works scalar start = readScalar(dict.lookup("startTime")); scalar end = readScalar(dict.lookup("endTime")); label nDumps = 5; os << ((end - start)/nDumps);*/ //================================================== //how to get the current time within controlDic??? //Tried but Not work //scalar t=this->db().time().value(); //error: invalid use of ‘this’ in non-member function //scalar t = runTime().value() ; //error: ‘runTime’ was not declared in this scope //scalar t = timeDirs.last().value(); //error: ‘timeDirs’ was not declared in this scope //scalar t = time().value(); //error: too few arguments to function ‘time_t time(time_t*) label t0 = 0.4; if (t <= t0) { os << 0.05; } else { os << 0.02; } #}; }; http://www.cfd-online.com/Forums/ope...ntroldict.html http://www.openfoam.org/version2.0.0...me-control.php http://www.cfd-online.com/Forums/ope...me-scalar.html Thanks in advance. |
November 4, 2014, 14:36 |
you'd like just to update writeInterval, depending on current time, you can create controlDict_1 with writeInterval_1, controlDict_2 with writeInterval_2 and use timeActivatedFileUpdate like below: Code:
functions { fileUpdate1 { type timeActivatedFileUpdate; functionObjectLibs ("libutilityFunctionObjects.so"); outputControl timeStep; outputInterval 1; fileToUpdate "$FOAM_CASE/system/controlDict"; timeVsFile ( (-1 "$FOAM_CASE/system/controlDict_1") (10 "$FOAM_CASE/system/controlDict_2") ); } } |
November 6, 2014, 07:12 |
duan
Rep Power: 12 |
For alternative,
I also wrote a script, to run the case in 3 steps: 0=>t1 ,with write time interval WI1 t1=>t2 ,with write time interval WI2 t2=>t3 ,with write time interval WI3 It's not a very good solution, but works. If someone is interested, see the attached file. |
July 25, 2015, 03:47 |
SM
Rep Power: 15 |
Does any one know how to get
scalar t = runTime().value Code:
writeInterval #codeStream I am getting the same error as reported here Code:
system/controlDict.#codeStream:40:13: error: ‘runTime’ was not declared in this scope |
July 25, 2015, 11:43 |
Tobias Holzmann
Rep Power: 51 |
It's more like:
scalar t = U.runTime().value();
Keep foaming, Tobias Holzmann |
March 22, 2016, 09:25 |
Carles
Rep Power: 10 |
Hi Tobi,
I tried Code:
scalar t = U.runTime().value(); Code:
error: ‘U’ was not declared in this scope Can you elaborate a little more about that and the namespace option? Thanks! |
March 21, 2021, 12:51 |
#8 | |
Rep Power: 17 |
March 22, 2021, 05:53 |
#9 |
Andrea Di Ronco
Rep Power: 9 |
I didn't try myself, but you should be able to access the mesh database, and then the simulation time with something like
db().time().value() In the codeStream documentation (https://cpp.openfoam.org/v6/classFoa...m.html#details) there should be an example on how to access the database from within a codeStream instance: Code:
someEntry #codeStream { code #{ const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); ... #}; }; Andrea |
March 23, 2021, 04:09 |
#10 |
Tobias Holzmann
Rep Power: 51 |
If you call db() you need an object. It is the same as with U.time().value(). U is an object of e.g., volVectorField.
It is not possible to just call db().time().value(). Probably this works: Code:
this->db().time().value(); Depending if »this« is a pointer or a reference you have to choose the point ».« operator or the other one »->«.
March 23, 2021, 04:29 |
#11 | |
Andrea Di Ronco
Rep Power: 9 |
If you already have some object U like a volScalarField, then it is much easier to just call U.db(). If not, this->db() may do the job in general but since I wasn't sure about what is returned by this in a codeStream context, my suggestion was to look at the documentation and see how to retrieve the simulation database from the current dictionary. Andrea |
March 23, 2021, 04:31 |
#12 |
Tobias Holzmann
Rep Power: 51 |
Does not fit 100 % but here is something similar.
https://www.youtube.com/watch?v=cvWaXBnEz1U&t=1095s
March 27, 2024, 05:29 |
#13 |
I meet the same issue here. Does anyone know how to get the current time in the controlDict via codeStream? |
controldict, current run time, write control |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
