Model evaporation of solution
Old   March 2, 2024, 11:31
Default Model evaporation of solution
Liu Yajing
zjuliu is on a distinguished road
Is there a solver or similar solver that can model the transfer of one phase of liquid to another phase, while also allowing for the solution of concentration profiles within the phases.
Like the evaporation of the water in brine improves the concentration of the salt
zjuliu is offline   Reply With Quote
Old   March 19, 2024, 10:43
Shravan
Severus is on a distinguished road
If you are using the ESI release (any version) or Foundation release (version 7 or lower),
You can take a look at the Euler-Euler solvers such as reactingTwoPhaseEulerFoam or reactingMultiphaseEulerFoam.
Also, in ESI release you have the VOF solver such as interCondensatingEvaporatingFoam.
If you are using Foundation release (version 8, 9 or 10),
You can take a look at Euler-Euler solver such as multiphaseEulerFoam.
Thanks
Severus is offline   Reply With Quote
Old   March 23, 2024, 18:43
Liu Yajing
Thanks a lot for your valuable help! I will take a look.
Evaporation of water bridge : Which Model Should I Use ? ddr2007 Fluent Multiphase 0 January 19, 2024 05:34
Evaporation of Liquid Bridge: Which Model Should I Use ? ddr2007 FLUENT 0 January 13, 2024 05:23
Does the Lee model for evaporation guarantee a correct total evaporation volume? lzhaok6 Main CFD Forum 0 March 16, 2023 03:30
Solidification and evaporation model. Mohamed Mousa Fluent Multiphase 1 September 20, 2019 06:48
Evaporation and condensation Model in Fluent amy24d Fluent Multiphase 5 May 26, 2015 12:20
