writing a dictionary in parallel
Old   January 24, 2024, 09:57
Default writing a dictionary in parallel
Martin
skaal is on a distinguished road
Hi all,
I feel a bit stupid with this question but I have been staring at this and breaking my head for hours now and do not get why this does not work.
I create an IOdictionary:
    IOdictionary
        IOobject
            dictName,
            mesh.time().timeName(),
            "uniform",
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
and would expect that the object writes to the uniform directory in the time folder. It does so, but only into the serial / reconstructed one. Even if running in parallel.
What am I missing something here?
As a side note and in case that helps or makes a difference: I am running this in OF-10.
skaal is offline   Reply With Quote
Old   April 10, 2024, 06:36
Amirhossein Taran
amirhosseintaran is on a distinguished road
Hi Martin,
You can use -copyUniform flag when executing decomposePar or reconstructPar.
Bests,
Amirhossein.
amirhosseintaran is offline   Reply With Quote
Writing all continuity errors to a file using custom solver in parallel mode saurabh1011 OpenFOAM Running, Solving & CFD 1 September 14, 2022 20:44
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Problem writing to dictionary MrAndersson OpenFOAM Programming & Development 4 September 12, 2017 15:46
[mesh manipulation] Dynamic remeshing (mequite) in parallel not working [foam-extend-4.0] Peter_600 OpenFOAM Meshing & Mesh Conversion 4 August 1, 2017 06:07
Error during writing of fields in massive parallel simulations chbeck OpenFOAM Bugs 1 September 6, 2010 06:25
