April 10, 2024, 08:37 |
How to initialize zero vectorField?
S03r3n
Rep Power: 2 |
Hello together,
how can I initialize a vectorField with only zero values? The following command does not work for me: const vectorField abc=vectorField::zero; Thanks in advance! Best regards |
April 11, 2024, 02:46 |
#2 | |
Mark Olesen
Rep Power: 40 |
Odd. How can you initialize a vectorField without any size???? The following would work, but this is also clear from the documentation: Code:
label len = ...; vectorField abc(len, Zero); |
vectorfield |
loading fluent data and turbo initialize in CFD post | shohag | FLUENT | 0 | June 29, 2020 20:26 |
using codestream to initialize internal velocity | shaoyx | OpenFOAM Pre-Processing | 2 | February 25, 2020 17:23 |
Subtract number from every value in vectorField | ali.m.1 | OpenFOAM Programming & Development | 0 | October 16, 2017 12:21 |
power of vectorField | matthias | OpenFOAM Programming & Development | 0 | August 19, 2014 08:52 |
scalar points to vectorField | deji | OpenFOAM | 2 | January 26, 2012 12:28 |
