buoyantFoam problem with meshToMesh
Old   April 12, 2024, 09:59
Default buoyantFoam problem with meshToMesh
gmax is on a distinguished road
Hi everyone, I'm trying to make a simulation of a moving inflow, it should simulate the wearing out of an electrode. The Openfoam version is OF.org V10.
In this process I used dynamicMeshDict to make the mesh move, when the deformation of the mesh was no longer acceptable I wanted to do a meshToMesh.
In this step I have an error:
 FOAM FATAL ERROR:
 V0 is not available
 From function const Internal& Foam::fvMesh::V0() const
 in file fvMesh/fvMeshGeometry.C at line 296.
I'm trying to understand what's wrong but comparing it with movingCone I don't think there's any error in the setting.
Searching online I found that this problem was present in XiFoam as "XiFoam: Removed redundant rhoEqn solution after mesh topology change". The git hash is
7dd5c4d3fac0704492a5b81f3315abe7d3443a6f .
I tried to look for some redundancy in this case too but I couldn't find anything. Does anyone know this error or how to fix it
gmax is offline   Reply With Quote
Old   April 16, 2024, 11:40
can anyone help me?
Old   April 17, 2024, 12:22
At the moment I think the error occurs in this area of ​​the code:
         autoPtr<volVectorField> rhoU;
         if (rhoUf.valid())
             rhoU = new volVectorField("rhoU", rho*U);
       // Update the mesh for topology change, mesh to mesh mapping
         mesh.update()
I think something is interfering with mesh.update(). I tried to understand in update() of the MeshToMesh file what could go wrong but I still haven't been able to figure out what's wrong.if I comment mesh.update() the count continues correctly.
All fields are printed correctly (even V0). It makes me think something is going on with directories.
Old   April 23, 2024, 03:48
it seems that the error is generated from this point, we are in fvMeshGeometry.C.
 const Foam::volScalarField::Internal& Foam::fvMesh::V0() const
293 {
294
295     if (!V0Ptr_)
296     {
297         FatalErrorInFunction
298             << "V0 is not available"
299             << abort(FatalError);
300     }
301
302
303     return *V0Ptr_;
304 }
What I understand is that the *V0Ptr_ pointer is missing, inside the fvMesh.C inside the file I find a lot of information that has to do with V0Ptr_ does anyone know where the error could be?
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
