Adding a new temperature dependent viscositymodel?
Old   May 6, 2010, 03:56
Default Adding a new temperature dependent viscositymodel?
Dan Gadensgaard
dgadensg is on a distinguished road
Hi Foamers.
I am currently trying to implement a new viscosity model that is dependent on temperature. I can see that a few others in this forum has succesfully implemented the CrossWLF model, but i have not yet seen how they have done it.
My problem is how to read the volScalarField T that i have for temperature, created in createFields.H and calculated with a temperature equation.
Whenever i do this, it messes up in several classes, because the viscositymodel suddenly have an extra parameter T besides U and phi.
Does anyone have a way to get around this? or maybe even a working code to do this?
// Dan
dgadensg is offline   Reply With Quote
Old   May 8, 2010, 12:30
Default Solved
Dan Gadensgaard
Hi again.
There is no need to answer, as i have just solved this issue. However, i did in a somewhat alternative way, by adding the volScalarField T to all my transportmodels. It works, but it is not the most elegant solution .
// Dan
Old   May 12, 2010, 17:53
Johannes Baumann
johannes is on a distinguished road
Hi Dan,
I came across your thread just recently so I missed answering in time...
A few months ago I was in the same situation, searching for a CrossWLF viscosity model for OpenFOAM. Since I couldn't find any working code snippets floating around on the forum, I tried to implement it myself.
I don't know exactly if everything is implementet correctly, since I encountered some serious stability problems with increasing viscosity and VOF solvers.
However, maybe at least I can provide you with a 'more elegant' solution for your problem.
Assuming you already added volScalarField T to your CrossWLF class, you should be able to read it during the viscosity correction calcNu() using
const volScalarField& T = U_.mesh().lookupObject<volScalarField>("T");
Back then I lacked a suitable test case for validating the CrossWLF model, which was one of the reasons I stopped testing. Have you already found one?
Best regards,
Johannes
johannes is offline   Reply With Quote
Old   May 13, 2010, 02:32
Dan Gadensgaard
Hi Johannes.
Thanks you for your answer. The code for accessing "T" in the models class you've provided is definetly more elegant, as iv'e implemented it by adding "volScalarField T" to all the constructors in the transportmodels.
As for the testcase, i am validating my implementation against the article: S. Radl, T. Tritthart, J.G. Khinast: "A Novel Design for hot-melt extrusion pelletizers", brought in Chemical Engineering Science, by Elsevier. In this article they have also use OpenFOAM, and they have shown the development of flow and temperature through a capillary die hole.
Note that I have not implemented the CrossWLF model, but instead added an exponential term to the powerLawModel.
Best Regards,
Dan
Old   May 13, 2010, 06:39
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Is that really more elegant though? If you're looking for better programming practice then it is surely preferable to pass temperature through the constructor, as opposed to looking the temperature up in the object registry. Or you could just pass it through a new member function when you want to evaluate a new viscosity.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   May 13, 2010, 07:32
Dan Gadensgaard
Well, i see your point, but passing it through the constructor is in my opinion only an elegant solution if it done consistenly throughout the code, which requires a respectible amount of work. This will also result in the volScalarField T being added to many classes, without ever being used.
I am sure that you could pass it through a new member function, but being on the "beginner"-level in OpenFOAM, this will take me a considerable amount of time to do.
// Dan
Old   May 13, 2010, 07:53
I would have a look at how the thermophysical models are implemented, in particular how the basic/psiThermo and basic/rhoThermo inherit from basicThermo.
Obviously, it may not be worth the effort, but it may be quite satisfying to try!
Old   May 19, 2010, 04:58
Default problem with adding a viscosityModel
xianghong wu
wendywu is on a distinguished road
Hi, foamers,
I am adding a viscosityModel into OF. I set up a folder named myViscosityModel into viscosityModels folder, looks like PowerLaw. Surely I set up myViscosityModel.C
and myViscosityModel.H. when I finished these I compile it with command "wmake libso".
there comes an error in the results:
"myViscosityModelCoeffs_lookup" was not declared in this scope.
the myViscosityModel.C file is as follows:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 1991-2008 OpenCFD Ltd.
\\/ M anipulation |
#include "fvCFD.H"
#include "myViscosityModel.H"
#include "addToRunTimeSelectionTable.H"
#include "surfaceFields.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
namespace viscosityModels
{ defineTypeNameAndDebug(myViscosityModel, 0);
viscosityModel,
myViscosityModel,
dictionary
// * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::myViscosityModel::calcNu() const
{ //shearrate
//- in your class, we can obtain the temperature. The only possible way is looking up "T" through objectRgistry.
const volScalarField & T=U_.db().lookupObject<volScalarField>("T");
volScalarField shearrate=max(minshearrate_,sqrt(2.0*((symm(fvc::g rad(U_))) && (symm(fvc::grad(U_))))/3.0)); //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷
volScalarField Z=shearrate*(exp(deltaH_/(R_*T)));
return asinh(pow(Z/A_,1.0/n_))/(3*beta_*shearrate)/rho_;
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
Foam::viscosityModels::myViscosityModel::myViscosi tyModel
const word& name,
const dictionary& viscosityProperties,
const volVectorField& U_, //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷
const surfaceScalarField& phi
: viscosityModel(name, viscosityProperties, U_, phi), //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷
myViscosityModelCoeffs_(viscosityProperties.subDic t(typeName + "Coeffs")), //********what is this for???
rho_(myViscosityModelCoeffs_.lookup("rho")),
R_(myViscosityModelCoeffs_.lookup("R")),
A_(myViscosityModelCoeffs_.lookup("A")),
beta_(myViscosityModelCoeffs_.lookup("beta")),
deltaH_(myViscosityModelCoeffs_.lookup("deltaH")),
n_(myViscosityModelCoeffs_.lookup("n")),
minshearrate_(myViscosityModelCoeffs_.lookup("mins hearrate")),
nu_
IOobject
( name,
U_.time().timeName(), //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷
U_.db(),
IOobject::NO_READ,
IOobject::AUTO_WRITE
calcNu()
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
bool Foam::viscosityModels::myViscosityModel::read
( const dictionary& viscosityProperties
viscosityModel::read(viscosityProperties);
myViscosityModelCoeffs_ = viscosityProperties.subDict(typeName + "Coeffs");
myViscosityModelCoeffs_.lookup("rho") >> rho_;
myViscosityModelCoeffs_.lookup("R") >> R_;
myViscosityModelCoeffs_.lookup("A") >> A_;
myViscosityModelCoeffs_.lookup("beta") >> beta_;
myViscosityModelCoeffs_.lookup("deltaH") >> deltaH_;
myViscosityModelCoeffs_.lookup("n") >> n_;
myViscosityModelCoeffs_lookup("minshearrate")>>min shearrate_;
return true;
the error is located at the last line: myViscosityModelCoeffs_lookup)"minshearrate")>>min shearrate_;
Anybody knows the reason? Thanks in advance.
Wendy
wendywu is offline   Reply With Quote
Old   May 19, 2010, 05:00
Default myviscosityModel.H
xianghong wu
here is the File "myViscosityModel.H"
\\ / O peration |
\\/ M anipulation |
Class
Description
Standard viscoPlastic non-Newtonian viscosity model.
SourceFiles
myViscosityModel.C
#ifndef myViscosityModel_H
#define myViscosityModel_H
#include "viscosityModel.H"
#include "dimensionedScalar.H"
#include "volFields.H"
namespace Foam
{ namespace viscosityModels
Class myViscosityModel Declaration
class myViscosityModel
: public viscosityModel
// Private data
dictionary myViscosityModelCoeffs_;
// dimensionedScalar k_;
// dimensionedScalar n_;
// dimensionedScalar nuMin_;
// dimensionedScalar nuMax_;
// volScalarField shearrate_;
// volScalarField Z_;
dimensionedScalar rho_;
dimensionedScalar R_;
dimensionedScalar A_;
dimensionedScalar beta_;
dimensionedScalar deltaH_;
volScalarField nu_;
dimensionedScalar minshearrate_;
// Private Member Functions
//- Calculate and return the laminar viscosity
tmp<volScalarField> calcNu() const;
public:
//- Runtime type information
TypeName("myViscosityModel");
// Constructors
//- Construct from components
myViscosityModel
const word& name,
const volVectorField& U,
// Destructor
~myViscosityModel()
// Member Functions
//- Return the laminar viscosity
tmp<volScalarField> nu() const
{ return nu_; }
//- Correct the laminar viscosity
void correct()
{ nu_ = calcNu(); }
//- Read transportProperties dictionary
bool read(const dictionary& viscosityProperties);
} // End namespace viscosityModels
} // End namespace Foam
#endif
Thanks,
Wendy
Old   May 19, 2010, 05:04
return true;
Wendy
You forgot the dot in that line:
myViscosityModelCoeffs_.lookup("minshearrate")>>mi nshearrate_;
You should also start another thread as this doesn't really relate to what was being discussed earlier.
Old   May 22, 2010, 05:47
xianghong wu
Laurence,
Thank you so much. Sorry for being so careless.
Wendy
temperature, viscosity models
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Temperature Dependent Fluid Properties eliwide OpenFOAM Running, Solving & CFD 4 December 15, 2012 19:21
Poor convergence with temperature dependent density on modified pisoFOAM ovie OpenFOAM 1 March 20, 2011 03:19
Multicomponent with Temperature dependent SAKTI Siemens 3 September 15, 2008 22:09
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 01:22
