OpenFOAM - Dakota coupling/Issues with Dakota parameters file
Old   February 4, 2020, 12:34
Default OpenFOAM - Dakota coupling/Issues with Dakota parameters file
ilaj is on a distinguished road
I am looking to couple OpenFOAM with Dakota. I started with tutorials available in Wolf Dynamics. I have been working on the simple cavity gradient case. Here's the Dakota input file -
environment
tabular_data
tabular_data_file = 'table_out.dat'
method
conmin_frcg
max_iterations = 100
convergence_tolerance = 1e-4
max_function_evaluations = 20
variables
continuous_design = 1
cdv_initial_point -1.8
cdv_lower_bounds -2.0
cdv_upper_bounds 3.0
cdv_descriptor 'x1'
responses
num_objective_functions = 1
numerical_gradients
method_source dakota
interval_type forward
#fd_gradient_step_size = .000001
fd_gradient_step_size = 1.e-5
# to instead use analytic gradients returned by the simulator comment the
# preceding two lines and uncomment the following:
## analytic_gradients
no_hessians
sense 'max'
interface
fork
asynchronous
#evaluation_concurrency = 4
evaluation_concurrency = 1
analysis_driver = 'OF_D.sh'
parameters_file = 'params.in'
results_file = 'results.out'
work_directory directory_tag
copy_files = 'templatedir/*'
# uncomment to leave params.in and results.out files in work_dir subdirectories
named 'workdir' file_save directory_save
# when using conmin_frcg (above) with analytic_gradients (below),
# need to turn off the active set vector
When I run this file, I get the following error -
/params.in: line 1: 1: command not found
/params.in: line 2: -1.800000000000000e+00: command not found
/params.in: line 3: 1: command not found
/params.in: line 4: 1: command not found
/params.in: line 5: 1: command not found
/params.in: line 6: 1: command not found
/params.in: line 7: 0: command not found
/params.in: line 8: 1: command not found
When I add the aprepro command to the following statement in the input file,
named 'workdir' file_save directory_save aprepro
Here's the error I get -
/params.in: line 9: syntax error: unexpected end of file
It seems like the issue is with the Dakota parameters file format. But I am not sure how to fix it. Thank you for any help you can provide!
- Ilaj
ilaj is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 Yage OpenFOAM Community Contributions 18 February 15, 2016 02:02
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
