Accessing Patch Objects from Solver
Old   January 24, 2011, 07:48
Default Accessing Patch Objects from Solver
Nils Lavesson
nilsl is on a distinguished road
I am using OpenFOAM to solve an electrostatic problem involving several different potentials, represented by boundaries, that need to be optimized during the solution process. I am able to write optimization routines inside each boundary condition and change their values independently, but since the problem I am working on is quite strongly coupled this is not enough.
I need to optimize all the boundary conditions together. My plan is to find the pointers to all the relevant boundaries objects inside the main solver and write a routine there that handles the boundary value optimization. However, I have not been able to figure out how to do this.
Is there a way of accessing all the pointers to the boundaries (patchFields) inside the main solver? Maybe extracting them from the associated volField or from the fvMatrix? Do you know any other way to do something similar?
Cheers,
Nils
nilsl is offline   Reply With Quote
Old   January 25, 2011, 09:29
Misha Marie Gregersen
Misha is on a distinguished road
Hi Niels
I am not sure exactly how you want to access the boundary values from the main script, so maybe my suggestion is a bit off, however I give it a try:
I know you can fetch the values of for instance the internal field next to a boundary patch (here number 1) as a patch field for the volScalarField T through the fvMesh using:
mesh.objectRegistry::lookupObject<volScalarField>( "T").boundaryField()[1].patchInternalField()
Hope it helps.
~ Misha
Misha is offline   Reply With Quote
Old   January 25, 2011, 10:15
Stefan Herbert
herbert is on a distinguished road
Hi Nils,
it's hard to tell you what to do without knowing which kind of boundary conditions you are using. But if you want to set the gradient of a fixedGradient-BC of a volScalarField p at boundary no. 5 for example you can use
fixedGradientFvPatchScalarField& pPatch = refCast<fixedGradientFvPatchScalarField>(p.boundaryField()[5]);
scalarField& pGrad = pPatch.gradient();
and set for the gradient (pGrad) whatever you want. Note that you have to add
#include "fixedGradientFvPatchFields.H"
inside your header. Using other boundary conditions is working in a similar way.
Regards,
Stefan
@Misha: Your method is working if you need to know the internal field from within boundary conditions, but I think Nils is going to edit boundary condition from within top level solver.
herbert is offline   Reply With Quote
Old   January 26, 2011, 02:50
Nils Lavesson
Hi Misha and Stefan,
Stefan, the code you provided is exactly along the lines I was looking for. The exact implementation is not important, what I was looking for is how to get the patch objects. The real problem contains mostly fixed value boundary conditions, which I will probably modify using access functions.
Looking at the doxygen I realize how the whole thing works. p.boundaryField() gives me an object that has inherited a FieldField, which in turn has inherited a container with all the patch objects. Then I simply have to do a cast and I get what I was looking for.
Misha, your code also seems to get me the same objects. If I needed to get the same information and I didn't have access to the GeometricField object containing the electric potential, this would probably be the way to go.
Thanks a lot for your help.
Cheers,
Nils
Old   January 26, 2011, 05:33
Hi Nils and Stefan
Nils, good that you figured out how to access the object you needed!
Stefan, I tested my code in the top level solver, and it actually accesses the internal patch field. But of course, you can also use it within a boundary condition.
Best regards,
Misha
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
mapFields : internal edges Gearb0x OpenFOAM Running, Solving & CFD 3 April 19, 2010 09:02
