How obtain a Mach number value from a case run with Xifoam solver??
Old   June 15, 2011, 03:00
Default How obtain a Mach number value from a case run with Xifoam solver??
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Hi Foamers, I want to compute the Mach number from an case solved with XiFoam, but when I try to use the Mach utility from postProcessing velocityField library, but when I can do, the Mach utility give this error:
--> FOAM FATAL ERROR:
Unknown basicPsiThermo type hhuMixtureThermo<homogeneousMixture<sutherlandTran sport<specieThermo<janafThermo<perfectGas>>>>>
Valid basicPsiThermo types are:
11
ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<constTransport<specieTherm o<hConstThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<sutherlandTransport<specie Thermo<hConstThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<sutherlandTransport<specie Thermo<janafThermo<perfectGas>>>>>
From function basicPsiThermo::New(const fvMesh&)
in file psiThermo/basicPsiThermo/newBasicPsiThermo.C at line 63.
FOAM exiting
I am looking for some help with this, I have tow ideas of how I can compute the Mach number:
1. I am thinking about changing the thermo type in the Mach utility, but i no have experience about programming in openFoam then I'm not very sure that I have to do?.
2. Extract the gamma value and then post computing Mach with the post-processing value of U and T, but I don't know where I have modify to extract the gamma value?
computing the Mach number from::
M=U/sqrt(gamma*R*T)
If anyone can orient me by the right way to do that, I was very thankful.
best regards
Felipe
Felipe G
lfgmarc is offline   Reply With Quote
Isentropic Mach number definition Turbomachine CFX 3 August 16, 2023 05:52
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Mach number Vs Convergence trend saisanthoshm88 CFX 15 January 13, 2011 00:59
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
