kappaLayers is not loaded
Old   June 5, 2015, 03:09
Default kappaLayers is not loaded
Cartuns11's Avatar
Cartuns11 is on a distinguished road
I'm working on a thermal model using chtMultiRegionsSimpleFoam. Between two regions, the model has a turbulentTemperatureCoupleBaffleMixed with this definition:
type compressible::turbulentTemperatureCoupleBaffleMixe d;
Tnbr T;
kappa fluidThermo;
kappaName none;
thicknessLayers (1e-4);
kappaLayers (1.38);
value uniform 300;
The problem is, when the simulations has been carried out, the final T file has a error in the kappaLayers and thicknessLayers because both have the same value:
kappaLayers (1e-4);
could someone help me? do you the solution?
Thanks.Greetings
Cartuns11 is offline   Reply With Quote
Old   June 5, 2015, 04:27
Default kappaLayers is not loaded: solved
Cartuns11's Avatar
I have found the solution.
There is a error in the turbolentTemperatureCoupledBaffleMixed.C. In my file, in the line 282 and 283:
thicknessLayers_.writeEntry("thicknessLayers". os);
thicknessLayers_.writeEntry("kappaLayers". os);
OpenFoam only loads thicknessLayers....... I have changed:
kappaLayers_.writeEntry("kappaLayers". os);
and it works correctly.
greetings
openfoam, thermal baffles
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
nonuniform body force loaded from a text file Farshad_Noravesh OpenFOAM Running, Solving & CFD 3 March 26, 2016 05:20
How to simulate a dynamically loaded journal bearing with Fluent? okiro FLUENT 0 April 7, 2010 21:16
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
Module can not be loaded Kate Main CFD Forum 0 May 7, 2008 10:33
