solve continiuty for velocity
Like Tree1Likes
  • 1 Post By FelixL
Old   June 27, 2011, 13:04
Default solve continiuty for velocity
Illya Shevchuk
linch is on a distinguished road
Hi Foamers,
in compressible solvers continuity is solved for density:
solve(fvm::ddt(rho) + fvc::div(phi));
with mass flux phi.
But how can I solve continuity for velocity?
I already tried to solve:
    fvScalarMatrix UEqn
        fvc::ddt(rho)
      + fvm::div(rho,U)
And the compiler returned an error:
error: no matching function for call to ‘div(Foam::volScalarField&, Foam::volVectorField&)’
Then I tried: this one:
fvScalarMatrix UEqn
   fvc::ddt(rho)
+ fvm::div(fvc::interpolate(rho),U)
but then I got a type mismatch error:
error: no match for ‘operator+’ in ‘Foam::fvc::ddt(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double]() + Foam::fvm::div(const Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>](((Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&)(& U)))’
    fvScalarMatrix UEqn
        fvc::ddt(rho)
      + fvm::div(rho,phi)
error: no matching function for call to ‘div(Foam::volScalarField&, Foam::surfaceScalarField&)’
fvScalarMatrix UEqn
        fvc::ddt(rho)
      + fvm::div(fvc::interpolate(rho),phi)
error: no matching function for call to ‘div(Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >, Foam::surfaceScalarField&)’
fvVectorMatrix UEqn
        fvc::ddt(rho)
I'm looking forward for an expert-answer
Best,
linch is offline   Reply With Quote
Old   June 27, 2011, 13:53
Illya Shevchuk
I'm a little bit confused:
thus I am looking for a volVectorField U, my system of equations should be fvVectorMatrix. But the continuity equation is a scalar one and the term div(rho,U) is a scalar field. So for each cell I have 3x unknowns but only 1x equation, right?
On the other hand, it should be possible to obtain continuity-based velocities in 1D. How can it be implemented, if I want to start with an 1D-case?
Furthermore, if I prescribe the temporal density change for each cell and provide velocities for every boundary cell but one, only one velocity field is possible, that satisfies these conditions, am I right? So how this velocity field can be obtained?
Old   June 27, 2011, 14:37
Felix L.
FelixL is on a distinguished road
Hello, linch,
you are right, the continuity equation is a scalar equation so it can only be solved for a single unknown scalar. This may be the density (which would be the easy way) or any velocity component. Still the continuity equation is one equation, so even if you know the temporal variation and the mass fluxes at the boundaries, there will be aribitrary velocity fields which satisfy the continuity equation.
Just imagine the following setup:
A rectangular, twodimensional domain. The continuity equation is
\frac{\partial \rho}{\partial t} + \frac{\partial \phi_x}{\partial x} + \frac{\partial \phi_y}{\partial y} = 0
\partial \rho/\partial t shall be known throughout the domain and at every boundary face it shall be \phi_x= \phi_{x0} and \phi_y= \phi_{y0}.
Out of the box there come two different velocity fields to my mind which satisfiy the continuity equation: either one, where \phi_x(y=\mbox{const.})=\mbox{const.}, thus \partial \phi_x/\partial x = 0 or another, where \phi_y(x=\mbox{const.})=\mbox{const.}, thus \partial \phi_y/\partial y = 0.
The partial derivative of the other mass flux component is then equal to -{\partial \rho}/{\partial t}
So it's not possible to obtain a velocity field from the continuity equation without any additional information.
In 1D it should be possible, though, as long as the variation of density is known. Just treat the velocity component as a scalar.
Greetings,
Felix
2538sukham likes this.
FelixL is offline   Reply With Quote
Old   June 27, 2011, 18:02
Illya Shevchuk
Thank you Felix,
to treat the velocity as scalar is a great idea!
Old   June 28, 2011, 05:31
Illya Shevchuk
One more question Felix,
which boundary condition would you suggest for velocity for the open end, since no boundary condition is needed? In 1D, one velocity and known density changes are fully sufficient. Otherwise the system of equations is overdetermined. Is there any "no condition" boundary in OF?
Old   June 29, 2011, 09:41
Felix L.
I was thinking about it for a bit and I don't think it would make sense doing this with OpenFOAM.
If you know \rho(x,t) and you want to solve for \phi(x,t), the 1D continuity equation simply becomes an ODE. So unless you don't have any other PDEs coupled with the continuity equation, it would make much more sense solving this equation using an ODE solver and not with finite volume methods.
What's your intention, anyway, if I may ask?
Greetings,
Felix.
Old   June 30, 2011, 04:04
Illya Shevchuk
Thanks again Felix,
Well, I also have PDEs for enthalpy and components to solve. And the intention is to test, if diffusive heat and mass transfer as well as evaporation models are working in 1D, before adding the momentum equation.
That's the background.
continuity equation, velocity field
Solve Flow or VOF simultaneously ? Ramsey FLUENT 1 February 16, 2011 13:16
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 06:58
Solve for two or more "Temperatures" Rui CFX 12 September 9, 2008 21:58
How FVM will solve shock problem? michael Main CFD Forum 4 June 13, 2007 09:07
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 10:00
