modified code crashes in parallel
Like Tree1Likes
  • 1 Post By mabinty
Old   September 28, 2011, 12:06
Default modified code crashes in parallel
Aram Amouzandeh
mabinty is on a distinguished road
Dear all!
I modified a code (chtMRF) and it runs without problems on a single CPU. At the moment I parallelize (here on 4 CPUs), it crashes in the first time step (error message see below).
What I did is I introduced a source for the energy equation of region1 (last line):
tmp<fvScalarMatrix> TEqn
            fvm::ddt(rho*cp, T)
          - fvm::laplacian(K, T)
          - fvc::div(fvc::interpolate(Qr)*mesh.magSf())
where Qr is created as volScalarField(IOobject()) in "region1" and initialized with zero. In order to update the boundary field of Qr from "region0" according to a certain condition, I added the following before the energy equation is solved:
if(condition)
    Qr.boundaryField()[patchID] == QrRegion0.boundaryField()[patchID];
The solver crashes at the moment the energy equation of "region1" (modified one) is solved. Thus I assume that Qr is not "fully" updated from all CPUs. I m not sure if thats the problem but e.g. for the sum of a scalar value there is something like the "reduce" function which collects the value from all CPUs. Does somebody have an idea how i could avoid this problem??
I greatly appreciate your comments!!
Cheers,
Aram
Solving for solid region region1
[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #2 in "/lib/libc.so.6"
[0] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libfiniteVolume.so"
[0] #5
[0] in "/home/aa/OpenFOAM/aa-1.7.1/applications/bin/linux64GccDPOpt/yazdRadBC"
[0] #6 __libc_start_main in "/lib/libc.so.6"
[0] #7
[lws16:14262] *** Process received signal ***
[lws16:14262] Signal: Floating point exception (8)
[lws16:14262] Signal code: (-6)
[lws16:14262] Failing at address: 0x3e8000037b6
[lws16:14262] [ 0] /lib/libc.so.6(+0x33af0) [0x7fbe6783caf0]
[lws16:14262] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7fbe6783ca75]
[lws16:14262] [ 2] /lib/libc.so.6(+0x33af0) [0x7fbe6783caf0]
[lws16:14262] [ 3] /opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEER KS2_h+0xe75) [0x7fbe687027d5]
[lws16:14262] [ 4] /opt/openfoam171/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x14b) [0x7fbe6a8ebcfb]
[lws16:14262] [ 5] yazdRadBC() [0x4597f7]
[lws16:14262] [ 6] /lib/libc.so.6(__libc_start_main+0xfd) [0x7fbe67827c4d]
[lws16:14262] [ 7] yazdRadBC() [0x425549]
[lws16:14262] *** End of error message ***
mpirun noticed that process rank 0 with PID 14262 on node lws16 exited on signal 8 (Floating point exception).
mabinty is offline   Reply With Quote
Old   October 12, 2011, 09:47
Aram Amouzandeh
Dear all!
Found the solution to my problem mentioned above. I took the BC solidWallMixedTemperatureCoupled to see how boundary patches are handled in parallel, and voil:
        const directMappedPatchBase& mpp = refCast<const directMappedPatchBase>
                T.boundaryField()[patchID].patch().patch()
            // Force recalculation of mapping and schedule
            const mapDistribute& distMap = mpp.map();
        // Swap to obtain full local values of neighbour Qr
            mapDistribute::distribute
                Pstream::defaultCommsType,
                distMap.schedule(),
                distMap.constructSize(),
                distMap.subMap(),           // what to send
                distMap.constructMap(),     // what to receive
                Qr.boundaryField()[solidPatchID]
I compared simulations on a single CPU with the one on 4 CPUs and the results match well.
Cheers,
Aram
Bahram likes this.
Old   January 11, 2013, 05:15
Nicklas Linder
nlinder is on a distinguished road
Hi Aram,
it has been a while, but i looks as if i am facing the same problem right now. (see http://www.cfd-online.com/Forums/ope...-parallel.html)
I do not really get, what you changed to get it to work, could you explain that a liitle bit more detailed?
Thanks in advance.
Nicklas
nlinder is offline   Reply With Quote
Parallel Error in ANSYS FLUENT 12 zeusxx FLUENT 25 July 17, 2015 04:40
Own boundary condition modified simpleFoam erorr in parallel execution sponiar OpenFOAM Running, Solving & CFD 1 August 27, 2008 09:16
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 14:33
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
