How to write Make/options File
Like Tree6Likes
Old   October 17, 2011, 08:56
Default How to write Make/options File
camoesas is on a distinguished road
Hello Everybody,
I am trying to write my first utility (function was standing here :-).
I have started with a given one and applied some changes. But I donīt know how to adopt the 'options'-File in Make directory. I cant find any Information of how this file should be.
Can you give me some hints, literature, anything?
Thanks
Camoesas
OF - 2.0.0
camoesas is offline   Reply With Quote
Old   October 17, 2011, 14:51
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi Camoesas
What do you mean by function? A new function in the same .C file? Code in a separate header included in your .C? Both need no change in Make files/options.
If you mean a new .so library (a .H and .C that are separate from the solver but the header is included in the solver) you need to add the last line of:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I.../lnInclude \
    -I<yourLibraryName>/lnInclude \
Note that before the name of your library you add an "l". You also need to include the path to the new .C file in the files file (like the solvers .C).
If you want to develop a generic BC, follow this tutorial:
http://cfd.iut.ac.ir/files/Tutorial,...20Diego%20.pdf
This should also apply to generic libraries.
Note that you can use #codeStream starting from OF 2.x. It is quite powerful. It may give you what you need without having to go coding in depth.
Best regards,
Hisham
Hisham is offline   Reply With Quote
Old   October 18, 2011, 07:40
Hey Hisham,
thanks for your reply. I mean I am writing a new utility to calculate wallshearstress in compressible cases. sorry for the incorrect expression in the first post.
OF - 2.0.0
Old   October 18, 2011, 08:05
Hisham's Avatar
Hisham Elsafti
You make it appear as if I've misunderstood utility
Anyways, I haven't done that before but looking at an example utility say gmshToFoam.C, the files file is straight forward (also when you have more than one .C file)
gmshToFoam.C
OtherCppFile.C
EXE = $(FOAM_APPBIN)/gmshToFoam
But the options file will be tricky as it depends on which Foam libraries do you need in your code. My approach would be:
1. Be generous, when in doubt include the library.
2. Look for Foam utilities/solvers that use the same libraries you need and typically copy the library includes from there.
3. I do not think it is a problem to over include libraries in the make files but if one needs to be picky that can need time, reading, and trial to find out which includes are really needed. I guess compile error messages would help ease the search!
Good luck
Hisham
alia and saatt like this.
Old   October 18, 2011, 09:07
Hey Hisham,
sorry youre right, it appears as if you just understand BOLD. :-) I have fixed it in the first post.
I will do try and error and include some more libraries.
OF - 2.0.0
Old   October 18, 2011, 09:55
Here is the wmake output:
camoesas@chico:~/OpenFOAM/camoesas-2.0.0-dev/rhoWallShearStress> wmake
Making dependency list for source file rhoWallShearStress.C
SOURCE=rhoWallShearStress.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/meshTools/lnInclude -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/transportModels -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/thermophysicalModels/basic/lnInclude -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoWallShearStress.o
rhoWallShearStress.C: In Funktion ŧint main(int, char**)Ŧ:
rhoWallShearStress.C:65:33: Fehler: ŧRASModelŦ wurde in diesem Gültigkeitsbereich nicht definiert
In file included from rhoWallShearStress.C:106:0:
/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude/compressibleCreatePhi.H:49:23: Fehler: ŧrhoŦ wurde in diesem Gültigkeitsbereich nicht definiert
rhoWallShearStress.C:145:44: Fehler: no match for ŧoperator=Ŧ in ŧ((Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField*)wallShearStress.Foam::GeometricField<Type, PatchField, GeoMesh>::boundaryField [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]())->Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::<anonym>.Foam::FieldField<Foam::fvPatchField, Foam::Vector<double> >::<anonym>.Foam::PtrList<T>::operator[] [with T = Foam::fvPatchField<Foam::Vector<double> >, Foam::label = int](patchi) = Foam::operator*(const Foam::UList<double>&, const Foam::tmp<Foam::Field<double> >&)(((const Foam::tmp<Foam::Field<double> >&)((const Foam::tmp<Foam::Field<double> >*)(& Foam::mag(const Foam::tmp<Foam::Field<Type> >&) [with Type = Foam::Vector<double>]()))))Ŧ
/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude/fvPatchField.C:266:6: Anmerkung: Kandidaten sind: void Foam::fvPatchField<Type>::operator=(const Foam::UList<T>&) [with Type = Foam::Vector<double>]
/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude/fvPatchField.C:276:6: Anmerkung:                  void Foam::fvPatchField<Type>::operator=(const Foam::fvPatchField<Type>&) [with Type = Foam::Vector<double>]
/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude/fvPatchField.C:387:6: Anmerkung:                  void Foam::fvPatchField<Type>::operator=(const Type&) [with Type = Foam::Vector<double>]
rhoWallShearStress.C:139:43: Warnung: Variable ŧmutPwŦ wird nicht verwendet
rhoWallShearStress.C:60:33: Warnung: Variable ŧstateŦ wird nicht verwendet
make: *** [Make/linux64GccDPOpt/rhoWallShearStress.o] Fehler 1
OF - 2.0.0
Old   October 18, 2011, 17:05
Retired Super Moderator
Bruno Santos
Greetings to all!
@camoesas: See this tutorial: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam - Follow it closely and pay attention to the details
For a bit more, see also the online user guide: http://www.openfoam.com/docs/user/co...p#x10-690003.2
Note: I didn't pay much attention to the error messages in your post above Hopefully you'll figure it out after reading the links I've written down.
Best regards and good luck!
Bruno
alia and linyanx like this.
Old   October 18, 2011, 17:27
Hisham's Avatar
Hisham Elsafti
I think you need to add:
# include "RASModel.H"
before the int main
Weil es nicht definiert ist
And then you need to figure out which library does the "RASModel.H" compile to in Foam and include it in the make/options file.
You should treat further similar errors in the same manner (as illustrated in Bruno's links):
1. Include the header files you need
2. Figure out which library they compile to in Foam and add it to options file (be generous )
Regards
Hisham
Old   October 20, 2011, 04:06
HI,
@Santos: Thanks for the tutorial youīve posted. Iīve been browsing throw and its similar to the one of Tommaso. I have already tried this one, but it isnt working for OF-2.0.0
@Hisham: I have included:
#include "RASModel.H"
before int main. And checked the options file:
Make/options:
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/turbulenceModels \
    -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions \
    -I$(LIB_SRC)/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions \
    -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/RASModel \
    -I$(LIB_SRC)/turbulenceModels/compressible/RAS/RASModel \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
EXE_LIBS = \
    -lincompressibleRASModels \
    -lincompressibleTransportModels \
    -lbasicThermophysicalModels \
    -lspecie \
    -lcompressibleRASModels \
    -lfiniteVolume \
    -lgenericPatchFields
I have added the RASModel to make/options file (bold) but it still gives me the error:
SOURCE=rhoWallShearStress.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/meshTools/lnInclude -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/transportModels -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels/incompressible/RAS/RASModel -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/turbulenceModels/compressible/RAS/RASModel -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/thermophysicalModels/basic/lnInclude -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude -I/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoWallShearStress.o
rhoWallShearStress.C:67:33: Fehler: ŧRASModelŦ wurde in diesem Gültigkeitsbereich nicht definiert
In file included from rhoWallShearStress.C:108:0:
rhoWallShearStress.C:147:44: Fehler: no match for ŧoperator=Ŧ in ŧ((Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField*)wallShearStress.Foam::GeometricField<Type, PatchField, GeoMesh>::boundaryField [with Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]())->Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::<anonym>.Foam::FieldField<Foam::fvPatchField, Foam::Vector<double> >::<anonym>.Foam::PtrList<T>::operator[] [with T = Foam::fvPatchField<Foam::Vector<double> >, Foam::label = int](patchi) = Foam::operator*(const Foam::UList<double>&, const Foam::tmp<Foam::Field<double> >&)(((const Foam::tmp<Foam::Field<double> >&)((const Foam::tmp<Foam::Field<double> >*)(& Foam::mag(const Foam::tmp<Foam::Field<Type> >&) [with Type = Foam::Vector<double>]()))))Ŧ
rhoWallShearStress.C:141:43: Warnung: Variable ŧmutPwŦ wird nicht verwendet
This makes me sad!
OF - 2.0.0
Old   October 20, 2011, 04:17
Hisham's Avatar
Hisham Elsafti
I guess you have a missing point .... No really a missing point:
EXE_INC = \
     -I. \
EXE_LIBS = \
    -lspecie \
    -lfiniteVolume \
This point is very important because it points to the utilities own directory.
I hope this helps!
Regards,
Hisham
Old   October 20, 2011, 04:56
HI Hisham,
Unfortunately this point makes no difference. I have compared the error messages and they are nearly identical...
Is the order of the linked libraries and header files important?
OF - 2.0.0
Old   October 20, 2011, 05:12
Hisham's Avatar
Hisham Elsafti
Originally Posted by camoesas View Post
HI Hisham,
Can you echo the $(LIB_SRC) in the terminal:
$ echo $LIB_SRC
Old   October 20, 2011, 05:17
LIB_SRC: command not found
Let me guess: This isnt good?
OF - 2.0.0
Old   October 20, 2011, 05:33
Hisham's Avatar
Hisham Elsafti
I'm sorry I made a mistake
$ echo $LIB_SRC
without brackets.
If the variable is empty then you can try to use $FOAM_SRC instead.
Old   October 20, 2011, 08:07
HI Hisham,
I have tried both:
echo $LIB_SRC
is empty
echo $FOAM_SRC
returns: OpenFoam/Openfoam-2.0.0/src
OF - 2.0.0
Old   October 20, 2011, 08:47
Hisham's Avatar
Hisham Elsafti
I think you can replace LIB_SRC with FOAM_SRC in options file and compile, although I don't think that will solve the problem.
To be honest, I think you should copy a utility from foam and only change the name of the .H & .C files and the name in Make/ files & options .... and change to $(FOAM_USER_APPBIN) in the files file and then compile it (that should work).
After that try taking it one step at a time. With every change (not literally) do a compile, so you have early control over bugs.
Old   October 20, 2011, 16:48
Bruno Santos
Greetings to all!
"LIB_SRC" is defined in "wmake/Makefile": https://github.com/OpenFOAM/OpenFOAM...e/Makefile#L58
That is why it's not visible in the terminal/shell.
@camoesas: As for including the RASModel headers, use this instead:
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude \
-I$(LIB_SRC)/turbulenceModels/compressible/RAS/lnInclude \
If you had studied a bit more how other applications and utilities include headers, you might have figured out that the "lnInclude" folders have symbolic links (i.e., shortcuts) for all of the headers for that library where the folder is present. This is a simpler way to not need to include that long list of folders you were adding to the "options" file
More about this here: http://www.openfoam.com/docs/user/co...0-720003.2.2.1 - section "3.2.2.1 Including headers".
Best regards,
Bruno
hrhm_04 and reverseila like this.
Last edited by wyldckat; October 20, 2011 at 17:29. Reason: had a malformed sentence!
Old   October 20, 2011, 16:59
Hisham's Avatar
Hisham Elsafti
Hi Bruno
Thanks a lot! This is very informative!
Regards,
Hisham
Old   October 26, 2019, 05:03
idrees khan
idrees khan is on a distinguished road
Originally Posted by Hisham View Post
Hi Camoesas
EXE_INC = \
    -I.../lnInclude \
Best regards,
Hisham
Hi guys i'm new in OpenFoam.
plz i have a confusion in the option file
EXE_INC = \
is LIB_SRC evn variable?
EXE_LIBS = \
-lfiniteVolume \
-lmeshTools
what is the meaning of EXE_LIBS = \
-lfiniteVolume \
-lmeshTools
and where it lying?and how to go through this files?
please fully explain it.
thanks
idrees khan is offline   Reply With Quote
Old   May 22, 2020, 12:32
Ardalan
Ardali is on a distinguished road
EXE_INC = \
EXE_LIBS = \
-lfiniteVolume \
-lmeshTools
-lfiniteVolume \
-lmeshTools
thanks
You link to different libraries.
Ardali is offline   Reply With Quote
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
