developing icofoam in non-inertial system
Old   March 20, 2012, 20:45
Default developing icofoam in non-inertial system
luckygl is on a distinguished road
hello everybody,
I try to use non-inertial system to solve heaving elliptic plate.
My present case is very simple.It's a 2D elliptic plate heaving cosinely.I add a source term into the N-S equation developing icoFoam.My boundary conditions also are changed into non-inertial system.
The new solver can be compiled and run successfully.But the result is totally wrong.I don't know where the problem is.
I attach my test case, so that someone who know this (which is not really difficult ;-)) can give me a hint.
Best regards and thanks in advance for any reply
Monica
PS:here is my solver
#include "fvCFD.H"
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createFields.H"
    #include "initContinuityErrs.H"
    volVectorField Ftmp = F;//store the initial value of F
    volVectorField Uetmp = Ue;//store the entangling velocity
    Info<< "\nStarting time loop\n" << endl;
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        #include "readPISOControls.H"
        #include "CourantNo.H"
        dimensionedScalar t = runTime.value();// get current time
        F = Ftmp * cos(omega * t);//modify F of the internal field
        F.correctBoundaryConditions();//correct the boundary values
        fvVectorMatrix UrelEqn
            fvm::ddt(Urel)
          + fvm::div(phi, Urel)
          - fvm::laplacian(nu, Urel)
          + F//add the source item
        solve(UrelEqn == -fvc::grad(p));
        // --- PISO loop
        for (int corr=0; corr<nCorr; corr++)
            volScalarField rAUrel(1.0/UrelEqn.A());
            Urel = rAUrel*UrelEqn.H();
            phi = (fvc::interpolate(Urel) & mesh.Sf())
                + fvc::ddtPhiCorr(rAUrel, Urel, phi);
            adjustPhi(phi, Urel, p);
            for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
                fvScalarMatrix pEqn
                    fvm::laplacian(rAUrel, p) == fvc::div(phi)
                pEqn.setReference(pRefCell, pRefValue);
                pEqn.solve();
                if (nonOrth == nNonOrthCorr)
                    phi -= pEqn.flux();
            #include "continuityErrs.H"
            Urel -= rAUrel*fvc::grad(p);
            Urel.correctBoundaryConditions();
    //---update absolute velocity
     Ue=Uetmp * sin(omega * t);
     Ue.correctBoundaryConditions();//correct the boundary values
     Uabs = Urel + Ue;
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
luckygl is offline   Reply With Quote
Old   March 2, 2021, 11:42
tomas lopez olocco
tomi_foamer is on a distinguished road
did you solve it? I have a similar problem that im not able to solve it.
Thanks!
tomi_foamer is offline   Reply With Quote
heaving plate, icofoam, non-inertial system
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Need ideas-fuel discharge system Jan FLUENT 1 October 10, 2006 23:05
Need ideas-fuel discharge system Jan CFX 1 October 9, 2006 08:16
need ideas-fuel discharge system Jan Siemens 0 October 9, 2006 04:31
Need ideas-fuel discharge system Jan Main CFD Forum 0 October 9, 2006 04:27
