Add a field sources to buoyantPimpleFoam
Old   March 26, 2012, 06:51
Default Add a field sources to buoyantPimpleFoam
Samuele Z
samiam1000 is on a distinguished road
Dear foamers,
I have added the field source feature (see here) to the buoyanSimpleFoam solver. I called it buoyantSimpleFoam_Epta (attached)
I am now trying to do the same with the buoyantPimpleFoam. But I am finding it difficult.
Could you check my mew solver buoyantPimpleFoam_Epta (attached, too)?
Thanks a lot,
Samuele
PS: when I try to compile it I get the following error message:
lab@lab-laptop:~/OpenFOAM/lab-2.1.0/applications/solvers/buoyantPimpleFoam_Epta$ wmake
Making dependency list for source file buoyantPimpleFoam_Epta.C
SOURCE=buoyantPimpleFoam_Epta.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam210/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam210/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam210/src/finiteVolume/lnInclude -I/opt/openfoam210/src/meshTools/lnInclude -I/opt/openfoam210/src/finiteVolume/cfdTools -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/buoyantPimpleFoam_Epta.o
In file included from buoyantPimpleFoam_Epta.C:78:
UEqn.H: In function ‘int main(int, char**)’:
UEqn.H:14: error: no match for call to ‘(Foam::fvVectorMatrix) ()’
UEqn.H:16: error: no match for call to ‘(Foam::fvVectorMatrix) ()’
/opt/openfoam210/src/finiteVolume/lnInclude/readTimeControls.H:38: warning: unused variable ‘maxDeltaT’
make: *** [Make/linux64GccDPOpt/buoyantPimpleFoam_Epta.o] Error 1
samiam1000 is offline   Reply With Quote
Old   March 26, 2012, 10:16
Kent Wardle
kwardle is on a distinguished road
Did you try "sources.constrain(UEqn);" with no extra parentheses?
kwardle is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Adding Temperature field to IcoFoam yapalparvi OpenFOAM Programming & Development 14 November 19, 2015 04:57
Need help evaluating field by interpolation with a "lookup table" JohnRHawk OpenFOAM Programming & Development 2 June 28, 2011 13:27
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 12:06
