Dealing with BC's in OF 1.6
Old   February 1, 2010, 09:17
Default Dealing with BC's in OF 1.6
Vesselin Krastev
vkrastev is on a distinguished road
Hello everybody,
I am an almost brand new OF user and I think I have some problems to set appropriate boundary conditons for a 2d incompressible aerodinamic case. The case in question is made up by a rectangular ambient simulating the wind tunnel, with inlet and outlet sections at the two sides. Immersed into the "tunnel" there is a 2d solid profile (initially I started simulating the flow around a very simple geometry, for instance a rectangular section). The inlet value of the velocity field has to be of about 4.28 m/s, and the Reynolds number referred to profile's lenght is of about 10^5. The solver I wish to use is the pisoFoam standard one for incompressible and unsteady flows, initially coupled with a k-epsilon standard RAS model. I tried to set the BC's and the other dictionaries (contrloDict, fvSchemes and fvSolution) having a look to the tutorials, but the results I have obtained are not good, because the velocity field seems more like a potential case one rather than a turbulent one, and also because the solution reaches convergence almost instantly. Down below I post the bc's, an image of the velocity field and the other dictionaries contents, so I will be quite happy if someone of us could tell me what I'm doing wrong...
Thank you in advance
controlDict dictionary:
application pisoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.1;
deltaT 1e-04;
writeControl runTime;
writeInterval 0.01;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
fvSchemes dictionary:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
fvSolution dictionary:
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.1;
pFinal
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
UFinal
solver PBiCG;
tolerance 1e-05;
relTol 0;
k
solver PBiCG;
tolerance 1e-05;
relTol 0;
epsilon
solver PBiCG;
tolerance 1e-05;
relTol 0;
R
solver PBiCG;
tolerance 1e-05;
relTol 0;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
BC's for the velocity field:
internalField uniform (0 0 0);
boundaryField
INLET
type fixedValue;
value uniform (4.28 0 0);
OUTLET
type zeroGradient;
SOLID WALLS
type fixedValue;
value uniform (0 0 0);
BC's for the kinematic pressure field:
internalField uniform 0;
boundaryField
INLET
type zeroGradient;
OUTLET
type fixedValue;
value uniform 0;
SOLID WALLS
type zeroGradient;
BC's for the TKE (k):
internalField uniform 0.0687;
boundaryField
INLET
type fixedValue;
value uniform 0.0687;
OUTLET
type zeroGradient;
SOLID WALLS
type kqRWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
BC's for the TKE dissipation rate (epsilon):
internalField uniform 0.109;
boundaryField
INLET
type fixedValue;
value uniform 0.109;
OUTLET
type zeroGradient;
SOLID WALLS
type epsilonWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
BC's for the Reynolds stresses (R):
internalField uniform (0 0 0 0 0 0);
boundaryField
INLET
type fixedValue;
value uniform (0 0 0 0 0 0);
OUTLET
type zeroGradient;
SOLID WALLS
BC's for the turbulent viscosity (nut):
boundaryField
INLET
type calculated;
value uniform 0;
OUTLET
type calculated;
value uniform 0;
SOLID WALLS
type nutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
vkrastev is offline   Reply With Quote
Old   February 2, 2010, 06:13
Vesselin Krastev
Any suggestions?
Old   February 2, 2010, 06:32
Jiang
panda60 is on a distinguished road
Originally Posted by vkrastev View Post
Any suggestions?
Do you have initilized your velocity field with potentialFoam ?
and the initial value of epsion could be larger , for example 100 times than the real value.
Good luck.
panda60 is offline   Reply With Quote
Old   February 2, 2010, 07:52
Vesselin Krastev
Good luck.
1-No, I don't made any initialization of the velocity field. Is that always required for a transient simulation or it is simply a "good practice"?
2-I'll try to enlarge epsilon values and then I will post if there are some different results
Thanks
Old   February 2, 2010, 08:07
Vesselin Krastev
No changes after enlarging epsilon by a 10^2 factor...
Old   September 4, 2012, 11:58
maalan is on a distinguished road
vkrastev, did you finde how to solve your problem?? I am stucked with the same thing!!
Thank you in advance!
maalan is offline   Reply With Quote
Porous media and adjacent BCs Carno FLUENT 1 January 14, 2010 00:54
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 04:14
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
BCs for Pressure Correction Equation (SIMPLE) Bharath Somayaji Main CFD Forum 1 March 1, 2006 06:12
Need Assistance: BCs for k-e model implementation Dean Schrage Main CFD Forum 3 August 11, 2001 01:02
