July 3, 2012, 08:09 |
buoyantBoussinesqSimpleFoam
Primoz Ternik
Rep Power: 17 |
using the buoyantBoussinesqSimpleFoam (in Open Foam 2.1.1) I am trying to solve the laminar Rayleigh-Benard convection (laminar natural convection in a square cavity heated from bellow) for Pr=10 and Ra=1e05. I have set up the case, run the solver... Unfortunately, results for the dimensionless temperature and horizontal velocity along the vertical mid-plane (i.e. along x/L=0.50) are "not good"! They are compared with the results of O. Turan, N. Chakraborty, R.J. Poole (2012). Laminar Rayleigh-Benard convection of yield stress fluids in a square enclosure, Journal of Non-Newtonian Fluid Mechanics, Vol. 171-172, p. 83-96 and with the results obtained with "commercial" code! Can someone please check if I have done any obvious mistakes in setting up the case or is the problem with the solver?? In addition, I have the following question. Why is it necessary to have the following files (required for a turbulent flow) in a 0 directory - alphat, epsilon, k, kappat, nut??? If I run the case without these files (in a 0 directory) I get the following message: --> FOAM FATAL IO ERROR: cannot find file file: /home/ternik/OpenFOAM/ternik-2.1.1/Cavity_RayleighBenard/0/kappat at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Cheers, Primoz |
cavity, of-2.1.1, rayleigh-benard |
